Movement flicker
Jeff Loot
Movement flicker
on Dec 10, 2012 at 10:51:42 pm
Hey guys,
I just got the new imac and have found that in FCP 7 between cuts and some movement I am experiencing a flicker or a black frame, like it's running from a slow drive. I'm not sure why this has only just started happening with the new comp? Or is it something else I have missed?
Any help would be much appreciated, thanks!
Neil Patience
Re: Movement flicker
on Dec 11, 2012 at 4:52:42 am
Hi Jeff
Odd flickering and black frames on cuts is often a symptom of trying to edit directly with H264 or MP4 files.
What format are you editing with ?
best wishes
Neil
http://www.patience.tv
Jeff Loot
on Dec 12, 2012 at 2:35:47 pm
Hi there!
I'm cutting with ProRes. I was working exactly the same before on a slower MAC. Then I plugged the G-Raid drive into the new IMac, installed FCP7 and have these movement flickers. Could it be the monitor?
thanks!
Neil Patience
on Dec 12, 2012 at 7:42:24 pm
Hmm so if you are working on a previous project that was fine on the older MAC it does seem unlikely that anything has changed in terms of the media.
I suppose it could potentially be a monitoring thing although I would have thought it was unlikely. Does it always occur in the same place or is it random ?
Have you any other projects you can open and see if it happens there ? Does it only happen on this sequence or do you have any other sequences you can check ?
If you export a section that is displaying the flickering does it show up on the exported file or is that OK ?
Kinda hard to diagnose without seeing it really.
Maybe worth doing the usual prefs trash and permissions repair just to eliminate the basics.
http://www.digitalrebellion.com/prefman/ - this is the easiest way to trash prefs.
best wishes
Neil
Lee Caldon
on Mar 4, 2013 at 2:04:05 pm
I've been experiencing exactly the same problem since upgrading to a new iMac a couple of weeks ago. The flicker is only in FCP7, not in the export. No flicker using the same FCP file on my early 2012 MacBook Pro.
