Final Cut 6: making 48fps (real time footage) into smooth slow motion
Wesley Loyd
on Dec 10, 2012 at 6:49:48 am
I shoot on a hvx200a and shot two clips of myself playing rock paper scissors. One clip was ahot it 720 24pn set at 48fps , so the final shot is slow motion. The second is 720p 24p at 48fps with the final shot being in real time. If I slow the real time shot 50% in final cut, the image gets blurry or less smooth. Is my percent wrong to make the 48fps slow motion?
Shane Ross
Re: Final Cut 6: making 48fps (real time footage) into smooth slow motion
on Dec 10, 2012 at 10:09:26 am
You need to use Cinema Tools. I have a tutorial for that:
http://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
Shane
Little Frog Post
Rafael Amador
on Dec 10, 2012 at 10:44:52 am
Just to add something: Do it on duplicated clips, because you have them conformed, you can't go back to normal speed (48fps(.
rafael
http://www.nagavideo.com
