Time line wont play the sequence?
Vasja Mihelcic
on Dec 6, 2012 at 4:29:08 pm
Hello.
I was manipulating with frames in Cinema tools to get smooth slow motion effect. From 59,98fps went to 23,98fps. After going back to fcp 7 i could play the clip in preview, but not on the time line. ..it moves 3 frames and stops. I tried different time line settings. Time line is set on clip settings: 1280x720 24fps...There is a catch but i have a block, it has to be simple as cake...i just forgot long time not used fcp.
thx for any help
Tikal
Vasja Mihelcic
Re: Time line wont play the sequence?
on Dec 6, 2012 at 5:34:13 pm
I mean clip wont play on Time line...it moves 3 frames and stopes...
Shane Ross
on Dec 6, 2012 at 5:47:27 pm
What are the clip settings? Codec? What are the timeline settings?
Shane
Little Frog Post
Vasja Mihelcic
on Dec 6, 2012 at 7:44:41 pm
I exited the FCP 7 program and now it works fine...I could not do it before because i was exporting.
I happend while using cinema tool for smooth slow motion. Preview worked fine, when putted on time line was just stucked.
clip: 1280 x 720 24fps H.264
Time line: HDV 720p 24 i also tried several other settings.
Thanks for taking interest in my problem...
Shane Ross
on Dec 6, 2012 at 7:46:34 pm
[Vasja Mihelcic] "clip: 1280 x 720 24fps H.264"
BUZZZZZZZTT! Don't use H.264 clips in FCP. EVER. Transcode to ProRes. If you want to edit H.264 native, use Adobe Premiere Pro.
Shane
Little Frog Post
