Storage for 15TB in one go
Tore Jonssen
on Dec 1, 2012 at 12:11:31 pm
Planning a 17 episode docudrama with an estimated need of abot 12-15 TB storage for raw material. Footage is XDCAM HD422. Any good ideas for low cost storage solutions that can work for this purpose, apart from xsan and the likes? Been looking into things like Drobo etc., but not sure about performance.
The storage does not have to be redundant and does not need speed for access from more than one editing suite at a time.
Cutting on Mac Pros, so unfortunately all Thunderbolt devices are not an option either.
Thanks in advance!
Regards,
Tore Jonssen
Jeff Meyer
Re: Storage for 15TB in one go
on Dec 2, 2012 at 9:47:08 am
Sounds like a G-Tech G-Speed is right up your alley. I would suggest an ES or an ES Pro, both of which require a PCI card. Double the speed compared with a firewire drive. Pick RAID-0, or RAID-5 with a 25% penalty on total size for the redundancy.
Tore Jonssen
on Dec 2, 2012 at 9:51:12 am
Thanks all of you, think you've pointed me in the right direction here. I love this forum:-)
Regards,
Tore Jonssen
Tom Matthies
on Dec 5, 2012 at 2:47:12 pm
I've been using G-Speed es raids (RAID5) for a few years with no issues. You can configure a single 4-drive RAID using 4Tb drives or use more than one at RAID5 for safety.
E=MC2+/-2db
Tore Jonssen
on Dec 6, 2012 at 7:35:44 am
Thanks Tom. I eventually ended up with four of these from Raidon:
http://www.raidon.com.tw/content.php?sno=0000463&p_id=170 .
Does the same job as the G-Tech ES ones, and have USB 3.0 as well as FW800-ports.
Thanks a lot guys!
Regards,
Tore Jonssen
