recapture
Murry Rushman
recapture
on Nov 30, 2012 at 12:54:47 am
Need to recapture media for existing FCP sequence--have accurate logging info--Is there some way to capture just the media referenced in the sequence and NOT the original clips? Batch capture not an option from sequence? Media Manager not applicable... help!
Shane Ross
Re: recapture
on Nov 30, 2012 at 2:42:43 am
[Murry Rushman] "Media Manager not applicable... help!"
Why is it not applicable? That's how you do it. Is this tape or tapeless?
The second half of this tutorial shows how to recapture tapeless using the Media Manager.
http://library.creativecow.net/ross_shane/tapeless_online/1
Shane
Little Frog Post
Murry Rushman
Re: recapture
on Nov 30, 2012 at 3:44:25 am
Thanks! You're right. Got 'er done. Thanks for your response. Aloha :-)
Murry Rushman
Re: recapture
on Nov 30, 2012 at 3:42:55 am
so the way to do it is to create a new project, name and save it.
Drag the sequence you want to recapture into the browser of the new project.
Click on the sequence and open Media Manager. Select "Create Offline"
Open that new project up--sequence clips will be in "Master Clips" folder.
Open, arrange by reel number, highlight clips to recapture and hit Batch Capture.
Start feeding tapes.
Voila!
