Reconnecting Media to synced clips within Final Cut Browser?
Reed Saltz
on Nov 29, 2012 at 8:21:12 pm
Hello,
I've been shooting with a DSLR and off-camera audio. Some scenes were edited without syncing the off-camera audio (but the in-camera, lower quality audio remained intact). My sound person laboriously synced all the clips used in the project on a timeline, and we can save those newly synced clips as clips within the Browser.
I assumed that there should be a way to reconnect media to these browser clips (that exist within final cut, but not as raw files in the Finder) versus the original files. As far as I can tell, there is not. Do I need to export each clip in the browser as a separate file or is there a way to swap out the original clip files and swap in the browser clips?
Thank you!
Shane Ross
Re: Reconnecting Media to synced clips within Final Cut Browser?
on Nov 30, 2012 at 9:23:47 am
[Reed Saltz] "I assumed that there should be a way to reconnect media to these browser clips (that exist within final cut, but not as raw files in the Finder) versus the original files."
You assumed incorrectly.
[Reed Saltz] " As far as I can tell, there is not."
Correct.
[Reed Saltz] "Do I need to export each clip in the browser as a separate file or is there a way to swap out the original clip files and swap in the browser clips?"
Well, your best bet is this:
http://assistedediting.intelligentassistance.com/Sync-N-Link-X/
Next time, sync all your audio BEFORE you edit. That's the proper way to do it.
Shane
Little Frog Post
Sascha Engel
on Jan 5, 2013 at 9:53:05 pm
Did you get an answer to this question? If yes, please, let me know.
I'd be very interested in this as well.
Thanx.
Sascha
