Waveform problem with 2 users
Mitch Jordan
on Nov 29, 2012 at 8:21:04 pm
I'm working on a multicamera edit with another editor. We have 4 cameras and 5 channels of audio. We share our FCP7 projects on a server and our media is on a separate RAID. Each computer stores its waveform files locally. The first editor cut the multicam sequences on her computer. However, when I open the project on my computer, I cannot connect the waveform files. The waveforms would help me to see at a glance which person is talking.
I tried trashing my Waveform files and the Waveform folder to try to force FCP to redraw the files. No luck. I even copied the original files from her computer to my Waveform folder with no luck. I created a new sequence and even a new project and tried copying the edited sequence into it with no luck.
Does anyone know how else I can force FCP to redraw, or reconnect to, the waveform files?
Fraser Callum
Re: Waveform problem with 2 users
on Nov 30, 2012 at 10:46:07 am
I could be a premission's issue or due to the network setup, FCP just cannot see the files it's linking to.
Can you set your waveform folder on both machines to be on a central location that both machines can see? With the folder having Read/Write permissions for everyone.
Jaap Verdenius
on Dec 12, 2012 at 7:59:04 pm
Did you try making your media offline and then reconnecting?
And did you try exporting/importing your sequences via xml?
