Final Cut and After Effects Rendering
Nuno Martins
on Nov 29, 2012 at 5:36:52 am
Hi guys,
I have to setup a Render Farm for After Effects and Final Cut. What would you guys say is the best option ?
We have used a Compressor cluster before to render final cut stuff, would this work happily in compressor 4 with after effects too ?
Please, some advice would be most appreciated
Rafael Amador
Re: Final Cut and After Effects Rendering
on Nov 29, 2012 at 6:27:49 am
[Nuno Martins] "We have used a Compressor cluster before to render final cut stuff,"
When you "Send to Compressor" from FC, FC still rendering the sequence, so setting Compressor for higher performance will not affect FCs limitations on rendering.
FC is limited in terms of usable RAM (4GB) and CPUs.
rafael
http://www.nagavideo.com
