Changing Frame-rate so I can rotoscope
Jake Hoover
on Nov 28, 2012 at 5:02:32 pm
Hello, first time on this forum along with first time using final cut pro! My school has picked up a copy of Final Cut Pro and they've assigned us to do rotoscoping, if you don't know what it is check this out. Basicly , I need to make the frame rate from 30fps, to 12, or 24 fps... Is this a possible thing to do?
I need to do this because I need to have my 1 minute movie turned into the still frames, ex 1 minute movie at 24 frames per second would be 1440 frames, I'm sure you already understood that though.
Any help in this area would be MUCH apreciated!
Rafael Amador
Re: Changing Frame-rate so I can rotoscope
on Nov 28, 2012 at 5:14:23 pm
Your link is a mess of explanation.
But to make what you want, you can try this:
- Open your clip with QT, and Export > Still Sequence.
- Set the number of still you want (Animations traditionally used to be done with 18fps).
- Export.
rafael
http://www.nagavideo.com
Jake Hoover
on Nov 28, 2012 at 5:26:37 pm
I opened up quicktime and i only have three options under export, not quite sure where I should be looking.
Rafael Amador
on Nov 29, 2012 at 1:47:46 am
I guess that is QTX.
You need QT.7.
Rafael
