Imported audio sync lag- Audio format problem?
tom bailey
on Nov 27, 2012 at 4:09:14 pm
I'm having a sync issue with audio being sent to me from a sound designer: the sound goes progressively out of sync. Both of us are using the same Quicktime export, we have check our setting and both of us are working at 25fps, 48khz, but we have differing audio formats.
FCP browser says:
The QT is 16-bit integer, 481.6 K/sec
The sound is 24-bit integer, 281.2 K/sec
FCP tells me that the sequence is 32 bit floating point and I gather that this is a default value FCP converts the sequence to for processing within the sequence. My original sequence setting was 16-bit, I've changed the default sequence setting to 24 bit but when i made a new sequence and tried everything in there it didn't change anything.
What is causing this problem and what can i do to resolve it?
Many Thanks
Bailey
