Select all offline clips in a sequence
Dave Boampong
on Nov 26, 2012 at 4:02:04 pm
I was handed a sequence with some of the clips offline. They are mixed up throughout the sequence. Is there a way in FCP7 to search for and select only the offline clips in the sequence?
Dave
Shane Ross
Re: Select all offline clips in a sequence
on Nov 26, 2012 at 4:08:59 pm
Select them and do what?
No, you can't select only the offline clips in a sequence via a one button solution. You'd have to manually select them.
Shane
Little Frog Post
Dave Boampong
on Nov 26, 2012 at 4:37:53 pm
Thanks Shane.
The idea was to select the offline clips and reconnect them to their media. I will do it manually then. Thanks again.
Dave
Steven Cohen
on Nov 26, 2012 at 4:40:40 pm
Select all the clips in the sequence.
Go to reconnect them and then there will be 3 button on the upper right side.
Turn off the Online and Render buttons and it will only try to reconnect those that are offline.
Steve.
Shane Ross
on Nov 26, 2012 at 4:52:13 pm
What Steve said.
Shane
Little Frog Post
Dave Boampong
on Nov 26, 2012 at 5:03:19 pm
Thanks Guys :)
