Registry error on Final Cut Pro OSX 10.7.5
Javier Lopez
on Nov 22, 2012 at 2:52:29 pm
Hello gentleman,
I have an issue with Final Cut Pro, 2 days a go started to give me a "Registry Error" message along with: Make sure the program is properly installed, can anyone please provide any suggestion to solve this issue?. FCP gets stuck on this error window.
Regards,
Javier.
Steve Eisen
Re: Registry error on Final Cut Pro OSX 10.7.5
on Nov 22, 2012 at 6:23:41 pm
[Javier Lopez] "Make sure the program is properly installed, can anyone please provide any suggestion to solve this issue?"
Re-install the software
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Javier Lopez
on Nov 22, 2012 at 9:32:54 pm
I wanted to avoid "Re-installing", but I had found the issue, T-racks plugins was the problem, uninstalled the plugin, I had to run "Preference Manager" and "OnyX", running smoothly again without "Re-installing" FCP and all the plugins.
Thanks.
Michael Gissing
on Nov 22, 2012 at 9:56:14 pm
I hope you didn't just intall Lion over an older OS. Installing FCS2 on Lion is tricky because it doesn't have Rosetta. There is a work around and it has been discussed here before so I suggest you search this forum.
Javier Lopez
on Nov 23, 2012 at 2:51:07 pm
Hello Michael,
I did a clean install "Formatting the HD first", so far I had no issues.
Javier.
