FCP 7 Exporting audio creates run time difference and sync issue
Patrick Terry
on Nov 21, 2012 at 8:38:46 pm
Hello.
I am attempting to export some audio that I have conformed to a separate video file, but upon exporting the audio as a WAV the run time has changed and the file is out of sync.
I am exporting the audio with the exact same specifications as the sequence I am working in.
I've tried with multiple files and experience the same problem every single time. I've experimented with a wide variety of settings and yet the problem persists each time. The only successful export I have had is exporting a video file- the runtime stays constant and the sync is fine. Unfortunately the client needs separate audio files, and I can't seem to find a way to avoid this strange error.
Any suggestions?
Pt
