VHS/Hi8 Clips into FCP
Sean Hammes
on Nov 20, 2012 at 7:06:45 pm
I am wondering if it is possible to convert VHS and Hi8 videos to clips that I can directly import into Final Cut Pro?
I don’t want the digital clips to be transferred directly to a DVD. The most important thing is that the digital clip can be easily used in FCP.
Thank you very much.
Scott Sheriff
Re: VHS/Hi8 Clips into FCP
on Nov 20, 2012 at 8:27:54 pm
[Sean Hammes] "I am wondering if it is possible to convert VHS and Hi8 videos to clips that I can directly import into Final Cut Pro?"
Yes it is. You either need a capture card type device, or a HDV/DVdeck with external inputs that can convert on the fly and pass thru on FW for FCP Log and Capture.
Scott Sheriff
SST Digital Media
Multi-Camera Director, VFX and Post Production
The Affordable Camera Dolly is your just right solution!
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." ---Red Adair
