FCP 7 Slip angle in multicam - it is not in sync
Tina Hedegaard
on Nov 20, 2012 at 12:08:41 pm
Hi
I just experienced something annoying. I am editing a comedy show with 6 angles, now after I have done the rough cut I see that one angle is a few frames out of sync - It is the supertotal, so I can hardly see any mouth movement.
Is there any way to slip just this angle a few frames or is it from the beginning, do the multiclip correctly, and then recreate the rough cut?
Thanks in advance
Cheers
Tina Hedegaard
Editor | Assisting Editor
Final Cut Pro 7 | Media Composer 5.5.3/6.0.1.1
Mac OS 10.6.8| Mac OS 10.7.4
Phillip Van West
Re: FCP 7 Slip angle in multicam - it is not in sync
on Nov 21, 2012 at 4:39:51 am
You CAN adjust each angle individually. You hold down CNTL-SHIFT and then drag your mouse (horizontally) across the clip (in the multi-viewer) you want to resync. It should display the new relative time offset. It's in the manual. Hope that helps.
pvw
Phil Van West
Terra Nova Productions
Denver, CO
Video Production/Post-Production
Mac Pro 8-core 2.66GHz / 16GB RAM / OS 10.6.7 / FCP 7.0.2 / QT 7.6
