Clip OK in Viewer, Lower Res in Timeline
Johan Windh
on Nov 20, 2012 at 9:59:32 am
I am currently working on a project with material exported from FCP to Color, back to FCP, then to AE and finally back to FCP again.
The workflow:
The footage is shot with SONY EX1 (XDCAM HD) and first cut natively. Then copied to a new sequence which is ProRes HQ 422 with 10-bit rendering. This is exported and graded in Color and re-imported, exported as QT to AE.
I work in AE as ProRes and export again, LossLess and ProRes.
HereĀ“s the problem. When I look at my AE clips in the Viewer they look good. When I place them in the timeline again they are a bit lower Res. than in the Viewer..
Can someone give me some input on this?
Is the workflow optimal?
Any help is appreciated!
Regards,
Johan
Rafael Amador
Re: Clip OK in Viewer, Lower Res in Timeline
on Nov 20, 2012 at 3:40:20 pm
[Johan Windh] "The footage is shot with SONY EX1 (XDCAM HD) and first cut natively. Then copied to a new sequence which is ProRes HQ 422 with 10-bit rendering. This is exported and graded in Color and re-imported, exported as QT to AE."
you could skip the step of copying the EX-1 sequence and putting it on a ProresHQ sequence to be sent to Color. You don't win nothing this way. Just send to Color the EX-1 sequence and render to Prores HQ in Color.
rafael
http://www.nagavideo.com
