My play back monitor doesn't play the Time Line
Sam Alvar
on Nov 18, 2012 at 10:26:49 pm
Hi Gang
I haven't changed any thing
I edit FCP from my Mac to main monitor that works
but the second monitor doesn't play it back
Is that controlled with Preferences and what is the Magic
Dominic Legg
Re: My play back monitor doesn't play the Time Line
on Nov 19, 2012 at 11:12:01 am
How are the monitors linked to your computer?
Make sure your video playback settings are correct with sequence settings?
If you use a Kona or other card you will need to check in the settings for the card also
Motion Graphic / Video Editor
Sam Alvar
on Nov 19, 2012 at 3:18:04 pm
Thanks Dominic
the play back was working
I made no changes or pulled cords
and the monitor works but doesn't play the Time - Line
I've tried the FCP preferences and my MAC-- no go
