720/24p to 1080i60
Will Sanderson
720/24p to 1080i60
on Nov 16, 2012 at 7:49:21 pm
Hi all,
I am encoding for broadcast for the first time and have been told to encode:
DVCPro HD:
Format: Quicktime Movie
Compression Setting: DVCPro HD 1920x1080i60
Compressor Native Raster: 1280x1080 (1920x1080)
Frame Rate: 29.97
Unfortunately, we have been shooting for web and haven't thought about broadcast, so most of our footage is 24p. Is there a way using FCP/Compressor/MPEG Streamclip to create the required files?
Every place I've seen has been suggesting a 3:2 pulldown using AE, but I unfortunately do not have the Adobe suite.
Thanks for your help,
Will
Alan Okey
Re: 720/24p to 1080i60
on Nov 16, 2012 at 8:43:25 pm
You can add 3:2 pulldown using Compressor.
Will Sanderson
on Nov 16, 2012 at 8:56:46 pm
How would I do the 3:2 pulldown using Compressor?
I'm encoding the files using Compressor now with the exact settings I need. Will it automatically accommodate for the different frame rates?
jerry wise
on Nov 16, 2012 at 11:39:42 pm
there is a "droplet" to add pull down using compressor. i think it was posted a year or so i believe. i've used it. works great for me.
