Exporting 10 bit uncompressed at 4:4:4:4
pat kelley
on Nov 16, 2012 at 3:26:13 pm
Someone has requested an archive file that is 10 bit uncompressed and 4:4:4:4 chroma.
Feeling a bit stupid here...I've been trying to figure out how to export a timeline that is both 10 bit uncompressed AND 4:4:4:4.
I've exported ProRes 4:4:4:4, which in QT player states that it is 8-bit, and the 10 bit uncompressed files state they are 4:2:2. Am I missing something obvious (most likely)?
Thanks for any help out there!
Rafael Amador
Re: Exporting 10 bit uncompressed at 4:4:4:4
on Nov 16, 2012 at 3:38:25 pm
Apple 10b Unc is YUV/422.
The only YUV/444(4) I know in the market is Sheer.
Not sure if they still are in business
[pat kelley] "I've exported ProRes 4:4:4:4, which in QT player states that it is 8-bit"
All the Prores family are YUV/422, except Prores444(4) that supports 12b RGB&YUV.
rafael
http://www.nagavideo.com
gary adcock
on Nov 17, 2012 at 10:00:38 am
[pat kelley] "Feeling a bit stupid here...I've been trying to figure out how to export a timeline that is both 10 bit uncompressed AND 4:4:4:4."
Uncompressed 444 is 10bit and can be either YUV or RGB.
4444 files are considered RGB + ALPHA- if there is not an alpha channel it is 444.
The QT player is always reading files @8bit.
You do not state anything about system or source files, if your originals were not that format you will need to create that color space for output.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
follow me on Twitter
@garyadcock
