Filters not applied when I export
Chris Schwartzy
on Nov 13, 2012 at 1:25:20 am
Hi all!
I've done a number of color correction filters in my sequence (3-way color correct, vignette, etc) and they look fine in my timeline/browser/etc... but then I either render them and then they are not visible anymore (the filters are still applied - but the effects of them are not showing in the rendered clips), or I do an export and the Quicktime looks the same way - like no filters were applied. Is this a setting somewhere that I'm getting wrong?? I feel it's only doing this on my FCP at work, not on my home computer.
Thanks for your help!
jerry wise
Re: Filters not applied when I export
on Nov 13, 2012 at 5:22:20 pm
go to sequence settings/render control/ and check to see if you have Render & Playback checked.
Chris Schwartzy
on Nov 16, 2012 at 9:34:04 pm
Thanks for replying... I have every possible render control checked, and it's still not keeping the renders. I'm so confused. Maybe just a glitch with this FCP install?
