Final Cut/XDCAM Error "Please Check that your XDCAM..."
Juliana Henriques
on Nov 9, 2012 at 11:59:53 pm
Hi everyone!
I´ve looked all over the forum and the internet, but couldn´t find the answer.
I´m trying to export a movie from Final Cut to a PDW-U1 (XDCAM writer).
The settings:
MPEG IMX 60 / 50 mbps
720X486
59,94fps
8 ch audio (all mono)
I get the error:
"Please Check that your XDCAM device is set up correctly, the REC INHIBIT indicator is off, and the disk is not full.
Video: IMX50 525 / 60i. Audio: 8 ch x 16 bit
Error writing MXF file (while checking valid edit rate)."
I´ve checked so many times the settings, it´s all good.
Others files did get successfully exported on the same Mac.
What is the problem?
Can anyone help?
Thanks for your attention! :)
Rafael Amador
Re: Final Cut/XDCAM Error "Please Check that your XDCAM..."
on Nov 10, 2012 at 12:51:23 am
Hi Juliana,
I would suggest you to ask in theCOW's " XDCAM Related" forum.
You may get better help than here.
rafael
http://www.nagavideo.com
Juliana Henriques
on Nov 10, 2012 at 1:45:03 am
Hi Rafael!
Thanks for the tip, I'll do that.
Julie.
