Problem with Twixtor
Isaac David Quesada
on Nov 7, 2012 at 7:18:45 pm
Hello editors
I have a video in 60fps, i want to convert it to 4000 fps, so I am using twixtor. If I change the Speed to 33% it works fine, looks good, but what I really want to do is change the Frame Number so I can control the exact amount of frames in that video. When I select Frame Number I only see a frozen image, no matter if I set it on 4000, 60, 30 or 0. Am I doing something wrong? Any help would be gargantually apreciated.
Isaac David Quesada
Re: Problem with Twixtor
on Nov 7, 2012 at 7:46:48 pm
Ok, I realized how the frame number works, kind of. I set two keyframes and it did moved, but that`s not what I`m looking for, anybody now how can I make it 4000 fps?
