Restoring HDSLR footage via Log and Transfer
Andrew Poag
on Nov 7, 2012 at 5:54:37 pm
I've run into a bit of a problem. A client has asked me to make some edits to an old FCP 7 project that was a collection of 5D, P2 and T2i footage. I had originally been able to ingest the T2i footage through Log and Transfer after editing the cameras.plst file in the EOS plugin v1.2 directory structure.
Since that time I had updated the the EOS plugin to v1.3 thereby overwriting my edits to the Camera.plst file.
Once I tried to restore the project I realized that Log and Transfer couldn't mount the T2i footage because I hadn't edited the camera.plst. I made a copy of the original Camera.plst file as a backup (just in case) and then went ahead and edited the code to add the T2i to the list of accepted cameras. Log and Transfer no recognizes the T2i footage BUT it no longer contains any of naming metadata we used when we logged the footage and also doesn't recognize the mounted drives for batch recapture. What's worse is that this has affected all of my projects. FCP no longer "remembers" any of the naming metadata or recognizes mounted drives for 5D footage in any of our projects on this computer.
I tried copying the original unaltered cameras.plst file back to it's folder but the problem remains.
Is there any known way to fix to this?
Thanks for any help that you can provide.
Andrew
Russell Lasson
Re: Restoring HDSLR footage via Log and Transfer
on Nov 7, 2012 at 6:13:59 pm
You'll have to go back to the old version of the canon log and transfer. We noticed that with v1.3 and decided not to update because it broke the connection to footage we had transferred in v1.2.
Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.net
Andrew Poag
on Nov 7, 2012 at 6:30:01 pm
Well the issues I'm having is that it's not only broken the connection with files I transferred with v1.2 but it's also broken the connection with files I transferred with v1.3.
Also, do you have any idea where I'd find a copy of v1.2. Canon's only seems to show v1.3 as a download option.
And on another note, has this been addressed in FCPX or is reconnection with DSLR footage a problem there too?
Russell Lasson
on Nov 7, 2012 at 6:40:13 pm
email me and I'll send you the old log and transfer tools that we have.
russ(at)colormill.net
Russell Lasson
Color Mill
Salt Lake City, UT
Andrew Poag
on Nov 7, 2012 at 7:05:31 pm
So I tried rolling back to v1.2 of the plugin but unfortunately that didn't help. At this point I'm unable to batch capture restore 5D material in any of my projects.
