Canon XF100 shots not all viable in FCP 7
Tommy Brown
on Nov 6, 2012 at 9:58:43 am
Hi there.
Was wondering if any of you might have come across this issue. We work on two shows where I am based (there are about 10 editors) with three full time cameramen. All three shoot on Canon cameras (1 XF100 & 2 XF300's). When we use the FCP 7 plugin not all the shots appear from time to time and are missed but if viewed in the Canon XF Utility they are there. 90% of the time however no one has time to duplicate the footage using the Canon XF Utility program and then transcoding to Prores 422.
Do any of you know how I can check what version of the plugin I have for FCP 7 or know of the issue why some shots are missing?
All the editors use FCP 7 on Lion and Snow Leopard with different levels of Apple updates (mine is fully updated Lion) and we still have the issue. I cut on iMac and on a Macbook Pro.
Your help will be appreciated, thanks.
Michael Gissing
Re: Canon XF100 shots not all viable in FCP 7
on Nov 6, 2012 at 9:11:20 pm
My experience of Log & Transfer is that you have to leave the computer alone when ingesting. Even though it appears to work as a background process, changing to another screen, starting to edit, checking emails or having a browser open increases the chance that a clip may only partial convert.
So I make sure no other software is open, setup the L&T batch and walk away. Afterwards I check that all shots are in and correct duration.
