FCP6, One Way Color Corrector
Maithili Pradhan
on Nov 5, 2012 at 7:53:12 pm
Hello,
I'm currently color correcting a documentary within FCP 6 (not Color).
The specs of my sequence:
Prores 422 sequence converted from DV footage shot on Panasonic AG DVX 100B 24P.
While I have been largely working with the 3 way color corrector, there have been places were I preferred the look of the one way color corrector in fcp.
Upon looking it up some more on the web, I came across posts that said that the one way color corrector filter may not be able to handle 10bit and downgrades the clip to 8 bit.
Is this a fact? Or have I misunderstood the statement? I would greatly appreciate any clarifications from the folks here.
Maithili
Steve Eisen
Re: FCP6, One Way Color Corrector
on Nov 6, 2012 at 1:23:48 am
You have more control over 3 way color corrector.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Maithili Pradhan
on Nov 6, 2012 at 1:30:39 am
Hi Steve,
True. But should one decided to go for one way cc for any reason, can one way cc handle 10 bit or will it treat the clip as 8 bit?
Maithili
Steve Eisen
on Nov 6, 2012 at 1:37:39 am
Download DaVinci Resolve Lite if you are so concerned about 10 bit vs 8 bit.
Steve Eisen
Vice President
Maithili Pradhan
on Nov 6, 2012 at 1:56:01 am
Thanks, Steve, for the option. I will certainly look into it.
Meanwhile, however, I would really appreciate it if someone would be able to clarify this for me. Mostly, all posts I have come across where people have asked this question- here or elsewhere- they've been nudged towards checking something else out. Obviously, this isn't the best option there is.
But... can one way color corrector handle 10-bit or not?
Steve Eisen
on Nov 6, 2012 at 4:14:40 am
If you took your time and converted your DV footage to ProRes, take your time and use the correct color correction. There are also 3rd party plug ins that will give you different looks. Magic Bullet Looks and Tiffen Dfx are just a couple. One Way Color is for quick and easy correction. This will not give you the correct look.
I believe in doing things the correct way. Just my opinion.
Steve Eisen
Vice President
Maithili Pradhan
on Nov 6, 2012 at 6:01:51 am
Steve,
I appreciate your taking the time to respond to my post. However, this does not really answer my question- which wasn't whether or not I should use the filter but whether or not the filter is 10 bit friendly.
If anyone has experience with this, please let me know.
Maithili.
Rafael Amador
on Nov 6, 2012 at 10:24:00 am
[Maithili Pradhan] "Upon looking it up some more on the web, I came across posts that said that the one way color corrector filter may not be able to handle 10bit and downgrades the clip to 8 bit."
Is not about 8/10b.
That filter works in 8b RGB. Avoid it unless you are rendering to something like Animation.
rafael
http://www.nagavideo.com
Maithili Pradhan
on Nov 6, 2012 at 2:50:58 pm
Thank you very much, Rafael. This really does clarify it for me.
Best,
Maithili
