what settings to use
Greg Ball
on Nov 3, 2012 at 5:02:53 am
I have a client who is giving me 1920x1080 footage converted from MTS files and also a DVD that's 720x480 letterboxed. I need to use all footage in a timeline and output a 720x 480 quicktime file.
I've converted everything to pro res 422. The majority of the footage is 1920x1080. Would you edit in a 720 x480 timeline? In doing so all the 19201080 footage is red lined and needs to render to play it.
Which way would you go here? Thanks.
Nick Meyers
Re: what settings to use
on Nov 3, 2012 at 9:05:37 am
"RED LINED" is a warning.
there is something wrong with your settings.
could be frame rate is off,
could be a dodgy codec (like H264 or something) oh, you say everything is PR422?
then frame-rate
have a closer look at your clip's settings vs your timeline settings,
report back.
in theory working in a 720x480 timeline is the way to go
is it ALL red line?
nick
Justin Keating
on Nov 3, 2012 at 9:45:33 am
I'd edit in a 720/480 sequence. That way you can re-position your HD footage knowing what it will ultimately look like in the frame. Plus you won't be stretching (and then down-scaling) your smaller footage.
Chris Tompkins
on Nov 5, 2012 at 2:19:59 pm
You'll need to render that HD material in an SD sequence.
Edit in an SD final size sequence.
Watch your field orders.
Chris Tompkins
Video Atlanta LLC
