Mixed Frame Sizes within the Same Project
Harrison Gruber
on Oct 31, 2012 at 6:18:56 am
I just completed logging and transferring all of my footage to start editing my project and lo and behold I notice that some of the footage is 1280x720 while some of the other footage is 1920x1080. What should I do? Can the two co-exist in the same sequence or will I have to do something to make them compatible?
Panicked in L.A.
Harrison Gruber
Re: Mixed Frame Sizes within the Same Project
on Oct 31, 2012 at 6:20:46 am
p.s. All footage is Pro Res 422 and 23.98 but the data rates are also different. Ahhhhhh!!!! :(
Rafael Amador
on Oct 31, 2012 at 9:49:04 am
No problem. Edit on a 1280x720 sequence.
If you do the other way, you will need to blow up a lot the 1280x720 stuff and will lose quality.
[Harrison Gruber] "p.s. All footage is Pro Res 422 and 23.98 but the data rates are also different. Ahhhhhh!!!! :("
As should be.
With the same time base and with same codec, the 1920x1080 will have much higher data rate than the 1280x720 footage.
rafael.
http://www.nagavideo.com
