Choppy Playback from IPHONE
Dj Acevedo-Zullo
on Oct 29, 2012 at 1:58:53 am
Ladies/Gentleman -
A complete FCP novice here.
When importing a file from my Iphone i am getting choppy playback after rendering.
I have read this could be due to my audio rate NOT being 48 (i am currently at 44).
Please offer some advice! (in the simplest terms possible PLEASE)
Thank you for the help!
Shane Ross
Re: Choppy Playback from IPHONE
on Oct 29, 2012 at 2:51:11 am
FCP won't edit the files the iPhone shoots. Not in the format they are in. Use Compressor to convert the footage to ProRes. There are presets. Just drag and drop
Shane
Little Frog Post
Dj Acevedo-Zullo
on Oct 29, 2012 at 2:11:38 pm
Are you referring to the Apple program "Compressor"? I wasn't lying when I said I was a novice.
What presets should I use exactly?
Thank you
Shane Ross
on Oct 29, 2012 at 9:49:00 pm
Yes. And in the SETTINGS (lower left box) Look in the APPLE folder, then FORMATS...in there you will see ProRes 422. Drop your video in the upper left box...than drag this setting onto that clip. Repeat if you have multiple clips. Then hit SUBMIT.
Shane
Little Frog Post
