Daisy Chain travel Hard Drive..?
Grant Wilber
on Oct 27, 2012 at 10:12:41 am
Don't really know where to put this thread.
But does anyone know of a travel hard drive that you can add to a daisy chain? Doesn't need to have two ports, can be at the end of the chain. But most of the small hard drives I have that aren't powered won't mount if I daisy chain through other hard drives, they have to be directly connected to the computer.
Is the only way to add into a daisy chain is to have the hard drive powered?
Using FW800 would be best.
Andrew Rendell
Re: Daisy Chain travel Hard Drive..?
on Oct 27, 2012 at 2:08:46 pm
I've got a Lacie Rugged 1TB which I use when I'm out and about which daisy chains quite happily at the end of a chain which goes MacBook Pro - GRaid (running on a power adapter) - Lacie on FW800. I suspect that the most important thing for the chain to work is that the GRaid has enough power on it's FW800 port to run the Lacie, tbh.
Gary Milligan
on Oct 28, 2012 at 8:51:10 pm
I 'Googled Firewire 800 hub' and got this:
http://www.amazon.com/NitroAV-8-Port-FireWire-Professional-Repeater/dp/B005...
HTH
Gary
