Pro Res Export Degradation
Joey Bania
on Oct 24, 2012 at 8:28:14 pm
A quick question regarding exporting with "current settings" from the timeline...
I recently finished a project and exported the final master to current settings (Pro Res 422). From there I used compressor to create a few different versions.
Now I realise I missed one small sponsor logo at the end of the film and I'd like to go back and put it in. The problem is, I deleted all my render files in the meantime so it will take another very long render (and I've been having "out of memory" issues a lot which means I'll probably have to sit through it).
My question is, if I simply import the Pro Res master to a new timeline and whip the 3 second logo on top at the very end, export using "current settings" again and then go through compressor once more, will there be any loss in quality? Will the footage be degraded in ANY way?
