FCP7 not saving project files to a network drive
Doug Lyle
on Oct 24, 2012 at 8:18:31 pm
FCP7 will not save projects to our network drive. A zero sized project file is created when I first do a "save as," but after that when I hit save, no file is actually saved. The auto save files do appear, but they show a file size of zero. I can save to my local RAID, which is my workaround.
I recently upgraded to 10.8, and FCP7 worked fine until I updated my Colorista II plug-ins from Red Giant. FCP7 would crash on exit every time after that. That's also when my saving issue began. I've uninstalled Colorista which fixed the crash on exit problem, but the network saving problem persists.
Renders do save to their proper place on the network drive. I suspect I'll have to re-install FCP7, but I thought I'd see if anyone else has heard of this phenomenon.
-Doug
MacPro 3,1 (Early 2008)
