Distorted images in Final Cut Pro
Ollie Jacobsen
on Oct 24, 2012 at 1:27:18 am
Ok Im sure its an easy fix... but why do my photoshop images always come into final cut studio distorted by -33?
I've dealt with having to manually un-distort them but this is doing my head in now!
Any help greatly appreciated.
PSD layered files - square pixels - same settings as the FCP sequence.
Thanks for reading!
Jamie Thompson
Re: Distorted images in Final Cut Pro
on Oct 24, 2012 at 11:14:05 am
Hi Ollie,
sounds like your File is anamorphic, or at least FCP thinks it is.
Right-click on the PSD in the bin, then item properties..., then format.
(Shortcut: Apple + 9)
Un-check the tick behind "Anamorphic", and voilla, no longer distorted.
Ollie Jacobsen
on Oct 25, 2012 at 11:39:41 pm
Hey Jamie,
Thanks for your help but nope anamorphic isn't checked. I tried checking it but still is distorted. It only does this to PSD files. JPEGS come in ok.
Also when I update a PSD file if its not exactly the same size it distorts it again. I'm gathering this version of FCP just isn't very photoshop friendly?
