DVD to FCP
Jim Makichuk
DVD to FCP
on Oct 16, 2012 at 6:07:21 pm
I need to edit (FCP7) a trailer from my 1980 feature and last time I got odd zebra fx on some cuts. That was 2011 on a re-released DVD letterbox. I will be editing to SD letterbox and about 3 min tops. Just curious what codec I should use as my previous experience had that zebra effect on the cuts. Not sure why.
Jim Makichuk
Re: DVD to FCP
on Oct 16, 2012 at 6:16:15 pm
Just found info in browsing. Will check that first.
Jim Makichuk
Re: DVD to FCP
on Oct 16, 2012 at 6:19:56 pm
Okay, other dvd wasn't relative, sorry for the confusion. I use streamclip to load and it works fine. In 2011 I captured the entire movie 87 min and cut a 3 min trailer but it had those zebra-like effects only on the cuts. And it would change cuts indiscriminately. Weird.
Shane Ross
Re: DVD to FCP
on Oct 16, 2012 at 6:23:41 pm
Sorry, I'm not understanding what you mean by "zebra like effects." Can you post a screen shot of this?
Shane
Little Frog Post
Mark Suszko
Re: DVD to FCP
on Oct 16, 2012 at 8:53:00 pm
I *think* I know what he means, and if I'm right, its an artifact you get when trying to do dissolves or wipes in the FCP timeline, using h.264 footage. I suggest exporting from streamclip to prores 422.
Jim Makichuk
Re: DVD to FCP
on Oct 16, 2012 at 9:09:15 pm
I seem to get it in cuts, will look at it right now and try to do a screenshot. thanks. But I'm wondering if I should just start over anyways...recapture whole movie.
Jim Makichuk
Re: DVD to FCP
on Oct 16, 2012 at 9:59:53 pm
Attached is a screenshot. These lines appear in the browser only. The timeline seems to have a single frame image between two clips (30-40% of time) but I can't find it in the timeline and some clips have a 1-2 sec freeze frame just before another clip.
Shane Ross
Re: DVD to FCP
on Oct 16, 2012 at 10:03:28 pm
Sorry, nothing was attached.
Shane
Little Frog Post
Jim Makichuk
Re: DVD to FCP
on Oct 16, 2012 at 10:08:08 pm
I loaded email twice but it isn't coming up. I uploaded it and it went somewhere. I'm more used to PC's which seem easier than here... on Mac command says I download to upload?
Jim Makichuk
Re: DVD to FCP
on Oct 16, 2012 at 10:53:39 pm
This is 7th attempt to download (or upload) screenshot. I cannot seem to figure out the secret, I download and upload all the time but this one is a mystery. I'm sorry to say I cannot up/download the screen shot. It goes somewhere I don't know.
Shane Ross
Re: DVD to FCP
on Oct 16, 2012 at 11:16:44 pm
There's a bunch of icons above the message box. One of them looks like a camera...sorta. Are you using that interface?
Shane
Little Frog Post
Shane Ross
Re: DVD to FCP
on Oct 17, 2012 at 12:24:24 am
THERE it is. You got it working on the Apple site:
https://discussions.apple.com/thread/4439576?tstart=0
Yeah...that's because of some wonky encoder. Try MPEG STREAMCLIP, rip it as DV50 or DV/NTSC (DV50 is better...also called DVCPRO 50). If that doesn't work, try DVDxDV.
Shane
Little Frog Post
Jim Makichuk
Re: DVD to FCP
on Oct 17, 2012 at 3:30:36 am
thanks Shane, it took 15 seconds to upload/download it in Apple. Still want to find out why it didn't here... I always have problems on this site, no record of past posts, etc... figured it had to do with encoding. Thanks for your help.
Jim Makichuk
Re: DVD to FCP
on Oct 18, 2012 at 9:03:56 pm
Shane...
Used streamclip again and DV50 and it worked perfectly. Editing a new version. Thanks
