post houses in L.A. with terranex
jim joyce
on Oct 15, 2012 at 3:39:34 pm
hey guys, do you know a good reasonably priced place that you could recommend for the "upscale/uprez"
process that the terranex suite of tools does?
thanks, jim
eric pautsch
Re: post houses in L.A. with terranex
on Oct 15, 2012 at 6:57:16 pm
There are PC tools like AVISnyth which will do just as good a job....and free. Not sure if this is strictly a tape to tape conversion? If so then you might go in that direction
David Davidson
on Mar 27, 2013 at 9:50:50 pm
Eric, I'm curious what configuration of AVISnyth do you use to get Alchemist results?
