FCP Drop down menu VERY slow
Kevin Bleicher
on Oct 11, 2012 at 3:47:16 pm
Hello all: Its been a while since Ive had problems with FCP. I 100% consider myself VERY lucky to have had all but 2 (including this one) major problems.
Recently, out of the blue, the menu on my FCP started to act up. Very slow. If I hit the menu items, takes about 5 seconds to show up. This happens everytime. Has anyone experienced this?
Thanks for your input!!
*No changes to hardware or machine
*No software changes
*FCP Version 7.0.3
*Happens with any setup on timeline, etc...
Jerry Hofmann
Re: FCP Drop down menu VERY slow
on Oct 12, 2012 at 9:08:31 pm
If trashing preferences for FCP doesn't clear up things like this, then it's likely time you performed a clean install and set up a new startup disk to clean things out. Seems to me this needs to be done periodically in any event, like once a year at least on a busy edit station.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
