10.8 Boris FCP7 Crash on start up
Rick Rohrkemper
on Oct 11, 2012 at 12:28:20 am
2 questions. 1) can I manually remove all Boris-Red-BCC-FEC-Grafitti manually, I tried the uninstalls and I must be missing something. Next I deleted the FCP from the applications folder and then used my FCS3 disks to reinstall FCP -- problem is FCP is blanked out and says skip -- I have all discs since FCP2. When I put in FCP6 says cannot run. So I janked over the FCP app from the disc I migrated from -- still crashes around Boris load. Any suggestions? I also used FCS remover - and removed checked the BORIS plugin removal -- but I am still crashing.
