FCP SD Tape out and PTVTmp Files
Jim Fink
on Oct 10, 2012 at 4:14:36 pm
So, I have been exporting some 80 minute shows to DigiBeta with an AJA IO. The current sequence is a 4ch. output. Previous outputs spend but a few minutes writing a temp file and then going out to tape.
Currently system is spending about 40 minutes writing a PTVTmp File to the Render Folder. Why is this happening. Usually it only writes a short header and starts right up. I restarted, and relaunched FCP 7 and same.
All is rendered, settings are same as stereo version was. Any clue to why the systems needs to build such a large pre-roll file. It's writen about 60 gig so far.
Jim Fink
New Century Digital Media
Chapel Hill, NC
Avid|DS
(919) 929-5228 Voice or 423-4363 (Cel)
http://www.NCDM.TV
jim@ncdm.tv
Michael Gissing
Re: FCP SD Tape out and PTVTmp Files
on Oct 10, 2012 at 8:45:02 pm
The need to render indicates that you have not fully rendered before edit to tape. Check your render settings in the render menu
Jim Fink
on Oct 10, 2012 at 9:37:33 pm
All is rendered - no change before or after tape out. Pretty much a flat file I am outputting to tape.
Jim Fink
Chapel Hill, NC
Avid|DS
http://www.NCDM.TV
jim@ncdm.tv
