DigiBeta / Playback Offset varies between HD and SD source.
Mike Lary
on Oct 9, 2012 at 5:48:59 am
Printing to DigiBeta from FCP 7.0.3 and Kona 3 (drivers up to date), I have to adjust the playback offset by one frame every time I switch between HD source and SD source. This happens consistently. It's not a big deal, but I'm curious as to why this would be happening.
Mike Lary
Digital Factory
Seoul, South Korea
Michael Gissing
Re: DigiBeta / Playback Offset varies between HD and SD source.
on Oct 9, 2012 at 5:57:49 am
The Kona has a frame delay in the down convert. You can set a frame delay in the edit to tape window by using the in/out time code and subtracting one frame.
Baz Leffler
on Oct 9, 2012 at 11:00:21 pm
....AND.... there are different settings in device control for SD and HD.
With my Multibtridges it if 5 frames for both.
Baz
Mike Lary
on Oct 10, 2012 at 1:46:35 am
Thanks, Michael. That makes perfect sense.
Mike Lary
Digital Factory
Seoul, South Korea
