Exporting PAL Footage, Flickering on Windows XP
Ashley vonClausburg
on Oct 8, 2012 at 2:46:53 pm
I have a sequence I need to export that contains some SD PAL footage (25 fps, 720 x 576, DV-PAL, Field Dominance: Lower) and some HD footage (25 fps, 1920x1080, XDCAM EX 1080i50, Field Dominance: Upper) My sequence settings match my PAL footage, except that I changed the field dominance to none and added a deinterlace filter (upper) to the HD footage.
I exported it with H.264 compression, 720 x 576.
Everything plays fine in Vimeo and Youtube except on computers running Windows XP (??). I get a weird, jagged flickering during parts that are bright/moving (different from a "staircasing" issue)
Any thoughts on what this could be? Am I doing something wrong with my settings?
