FCP 7 Requirement
Goutom Ain
FCP 7 Requirement
on Oct 4, 2012 at 5:21:14 pm
Dear All,
I am using full HD editing and it take much time to export a clip. So can anyone please update me the recommended hardware requirement for both imac with i7 processor and mac pro with dual quad core xeon processor.
Daniel Sametz
Re: FCP 7 Requirement
on Oct 4, 2012 at 6:23:02 pm
Hi, Goutom:
Have you converted the material to Prores? Maybe you are editing H.264 or other no editing codec. You need to give more details.
Goutom Ain
on Oct 5, 2012 at 4:45:43 am
Hi Daniel,
Nope. I use mp4, mov and also wmv in timeline. Final output is in h.264.
Alex Elkins
on Oct 8, 2012 at 12:38:59 pm
[Goutom Ain] "I use mp4, mov and also wmv in timeline"
There's your problem. FCP is built for editing using codecs in a mov wrapper. Even then, the contents inside the mov need to be compatible. Generally people convert everything to ProRes 422 before editing. Doing that ensures good performance.
Like Daniel said - you need to provide more information. What codec are the mov files you're using? (You can find out by opening them in QuickTime and pressing 'Cmd+i' for 'Info'.
Alex Elkins
Twitter: @postbluetv
http://www.postblue.tv
Post Blue showreel
Latest work: Greyhounds in Motion at 500fps
My Vimeo Pro page
Goutom Ain
on Oct 8, 2012 at 2:13:49 pm
I use Animation, LinearPCM, Timecode.
Daniel Sametz
on Oct 8, 2012 at 4:27:19 pm
I would recomend converting everthing to prores.
With flip for mac you can convert the wmv and with mpge Streamclip you can convert the mp4.
http://www.telestream.net/flip4mac/overview.htm you
http://www.squared5.com/
You can also watch Shane tutorial for Tapeless Workflow
http://library.creativecow.net/articles/ross_shane/tapeless-workflow_fcp-7/...
Depends on what is your final destination is the format of prores that you need but HQ is probably too much, if only web then I would go with LT.
Good Luck. :)
