Need recommendation for graphics card for Early '08 mac pro for FCPX install
Jacquie Nauman
on Oct 3, 2012 at 6:48:09 pm
Is this the right place to post this? I must finally move up from FCP 7 for work. Can't use FCPX on my system until I upgrade the graphics card. Per the tech requirements from apple I need OpenCL-capable graphics card or Intel HD Graphics 3000 or later. Some research sent me to this OWC link: http://eshop.macsales.com/item/Apple/6615718/ which is more my budget at $269 than the one Apple is recommending at over $879. Can anyone give me some feedback on this and what else I will need before buying the upgrade to X? Thanks in advance!
MAC: 2 x 2.8 Quad Core Intel Xeon
Memory: 6GB 800 MHZ DDR2 FB-DIMM
OS: Mac OS X 10.7.5
Hard Drive: WDC WD3200AAJS-41VWA0
Capacity: 319.21 GB (319,213,174,784 bytes)
Final Cut Pro 7.03
Neil Patience
Re: Need recommendation for graphics card for Early '08 mac pro for FCPX install
on Oct 4, 2012 at 4:53:38 am
Hi
I have that 5770 card in an old MACPRO 1.1 and it works perfectly with FCPX. You might want to add a bit more RAM as FCPX is 64 bit and is able to utilise that. Otherwise I dont think there is anything else you really need to get you going.
best wishes
Neil
http://www.patience.tv
