Text in Final Cut
Kevin Hilton
Text in Final Cut
on Oct 2, 2012 at 11:30:00 pm
I edited a movie in final cut its about an hour long and has a lot of text in it i just found a new font i want to use is there an easier way to change all of the fonts at once, than just doing each one individually?
Shane Ross
Re: Text in Final Cut
on Oct 2, 2012 at 11:45:31 pm
I wish. Sorry, alas, no.
Shane
Little Frog Post
Rob Tinworth
on Oct 3, 2012 at 1:53:02 am
If you just used the FCP text generator (not sure whether this works with Boris 3D), this is a really handy tool for subtitles:
http://www.spherico.de/filmtools/TitleExchange/
It's a little fiddly, but essentially you export an xml of a timeline with a single sample title in the font+style that you want to change everything to. With that xml you create a template in Title Exchange Pro.
Then export all your subtitles on one track as an xml, and use TEP to convert the xml, to an xml, but using the template you created. That will change the font - and any of the parameters in the text generator - of all the subtitles. Then reimport the new xml into FCP.
It's a real timesaver.
Rob Tinworth
http://www.1021.tv
Bouke Vahl
on Oct 3, 2012 at 3:33:06 pm
Or, just export to XML, do a search / replace in a text editor and be done with it.
Should not take more than 2 minutes...
Bouke
http://www.videotoolshed.com/
smart tools for video pros
