Compressor Timecode Generator Filter problem- creates black clip with timecode
Inbal Lessner
on Oct 2, 2012 at 11:28:00 pm
Hi all,
I actually use Avid MC for my editing work, but use compressor for encoding to Vimeo/DVD/Blu-Ray - never had this problem before.
I have a QT ref file (HD 23.98), which I import into Compressor and trying to burn a DVD with burn-in timecode.
The overlay looks fine in the Preview window, but when I encode to any format (QT/DVD) all I get is a black clip with running timecode.
I can render a self-contained QT with the timecode overlay in the Avid, but I prefer not to tie up my editing system with the render, if I can have Compressor do it while I work.
Any ideas?
Dan Lebental
Re: Compressor Timecode Generator Filter problem- creates black clip with timecode
on Oct 28, 2012 at 9:35:35 pm
I am seeing the exact same thing. My workflow is similar. I export QT reference file from the MC. I import to compressor and render out Quicktime movies in H.264 so I can pass through timecode(which is critical for my uses). So when I put the TC burn in filter in Compressor it renders black. Ugh
I would use Sorenson Squeeze but it cannot pass through timecode which is ridiculous.
Another alternative is to use CatDv -$99. Which can carry timecode and do burn ins while transcoding from QT ref.
Dan Lebental ACE
David Glasgal
on May 4, 2013 at 1:20:25 am
anyone ever figure this out? i've been using compressor for years doing this and just got this problem with an avid output batch that i'm doing bitc for. what's up
