Dynamic link
Dred33 Dred33
Dynamic link
on Sep 30, 2012 at 2:21:41 pm
I love FCP, i think that there are not comparisons with Premiere, but in the last one there il a very important plus:
the dynamick link to use its sequences into the Premiere's Time Line.
So i have to create the clip con AE and then export them without compression and re-import the clip in Final Cut, but thereby i codify the file 2 times, and to make some changes i have to re-open AE and re-export.
1-I can left AE to Motion (so i could import the sequenze in FCP Project), but i think AE is better and i know well it.
2- With Boris plugin i can finalize the work into AE, but every times that i have to modify some little things i have to open Final Cut, modify and re-export.
3- I could left FCP to Premiere, but... you know !! ;-D
How do you work with AE and FCP? Exporting and Re-importing ?
Shane Ross
Re: Dynamic link
on Sep 30, 2012 at 6:29:53 pm
Yup. Always have to export out of AE as QT, then import that into FCP. There is no, and never will be, dynamic linking into FCP.
Shane
Little Frog Post
Dred33 Dred33
Re: Dynamic link
on Sep 30, 2012 at 10:56:26 pm
And so? What you use to produce motion graphics, Motion or After Effect?
Shane Ross
Re: Dynamic link
on Oct 1, 2012 at 5:38:12 am
Both. But I don't produce that many graphics...I rarely do, and when I do I use templates, because that's not my area. I hire graphics guys to do them, or...as I said...I use templates. But I use both. AE is easier for me to grasp when I do
Shane
Little Frog Post
