Changing the inpoint on multiple clips, or create handles on multiple clips.
Kenny Holl
on Sep 29, 2012 at 2:24:13 pm
I videotaped a party. I captured the footage and it separated into 81 clips. Now I'd love to be able to put in dissolves between all of them. I know I can put them in the timeline, select all of them and change the duration by a certain number of frames (say -15 frames), but that only affects the outpoint. Is there a way to do all 81 inpoints at the same time.
i.e. is there any way to create handles on multiple clips at the same time?
Kenny Holl
Re: Changing the inpoint on multiple clips, or create handles on multiple clips.
on Feb 15, 2013 at 5:52:10 pm
New party, same problem. Only now I have over 200 clips. I'd love to trim them all at once to create handles on all, but I don't know how. Here's the easiest method I know of so far. I put all the clips in my timeline and highlight all of them. Then I go to duration and reduce the duration by, say 8 frames, which trims the outpoint on all the clips. Then I put them back into a new bin, and I manually add "+8" to each clip's input.
Is there a better way????
