Modify FCP clip after roundtrip to STP or Motion
Anmol Mishra
on Sep 26, 2012 at 1:09:24 pm
I am using FCP7 in FCS3.
When use a roundtrip and send to Motion or STP, the stap or motn file replaces the original clip in my timeline.
I have a format problem with Cineform, essentially FCP interprets all my Cineform clips as Upper Field instead of None Field Dominance.
Is there a way I can access the underlying clips and re-render after changing the Format -> Field Dominance to None ?
I noticed that this causes some stair stepping artifacts otherwise.
Rafael Amador
Re: Modify FCP clip after roundtrip to STP or Motion
on Sep 26, 2012 at 1:48:40 pm
make sure the Cineform clips shows as Progressive (NONE) in FCs Browser before dragging them to the time-line. Th e time-line must be NONE too, and the Motion project the same.
rafael
http://www.nagavideo.com
Anmol Mishra
on Sep 26, 2012 at 4:07:20 pm
Unfortunately many of these projects were created before I knew this..
I have the project settings as None.
Is there a way to access the clips in round tripped project to change their settings ?
Rafael Amador
on Sep 27, 2012 at 2:52:55 am
no idea.
the best solution when having problems round tripping is to export a self contained movie from Motion.
rafael
