Editing SD (DV50 PAL) - would SSD disk(s) work?
Niklas Wikman
on Sep 26, 2012 at 9:25:59 am
Apart from the fact that SSD disk are not as big as conventional disks (I think you can buy 470 GB SSD, but they cost about $800) can I use SSD as video disk at all?
We work with documentary and our number of simoultanous DV50 streams are perhaps not that many...
Should I stick with mechanical disks?
Rafael Amador
Re: Editing SD (DV50 PAL) - would SSD disk(s) work?
on Sep 26, 2012 at 9:29:46 am
Why not?
An SSD is just faster tan a mechanical disks.
rafael
http://www.nagavideo.com
Niklas Wikman
on Sep 27, 2012 at 1:42:48 pm
OK, so using an SSD disk (in a bus-powered 2,5" enclosure over FW800) would work just fine for me, shooting DV50 ?
Another question: would 5200 rpm be enough for DV50 and a few simoultaneous streams?
From what I understand 5200 rpm generates less heat.
If you are using bus-powered (FW800) enclosure, what brand/model do you use?
I used macsales/OWC up until last year, when the enclosure started to fail on me, not showing the disk content. (The disk itself worked fine in an externa SATA-dock).
Rafael Amador
on Sep 27, 2012 at 4:47:31 pm
Yes, should be fine to move a few DV50 threads in real time.
You shold be able to check the read/write speed of the HD with the "AJA System Test". Is included with any AJA drivers.
rafael
