Multicam viewer shows only one angle
Sawi Hsiwi
on Sep 23, 2012 at 9:12:57 pm
After creating a multiclip (only two angles), switching from sync off to open, when I start playing the track in the timeline the viewer defaults to one camera. When I pause playback both angles appear. I have experienced this with other clips but problem went away without knowing how it was fixed. (Perhaps a restart is needed?)
How can I avoid this problem? What am I doing wrong?
I am using Final Cut Pro 7.03, all clips are prores 422, nothing out of the ordinary. Thanks in advance.
Shane Ross
Re: Multicam viewer shows only one angle
on Sep 24, 2012 at 1:24:32 am
IN the RT menu on the timeline, make sure you have MULTICLIP PLAYBACK checked.
Shane
Little Frog Post
Grant Wilber
on Sep 24, 2012 at 4:17:21 am
Try going thru the trashing pref's and stuff.
This happens to me from time to time. Got no clue why, its just random. Sometimes if I restart and trash prefs it works fine. Sometimes I just gotta wait a day and it will work again.
