FCP7 crashes whenever I try to open a clip
Ryan Lim
on Sep 20, 2012 at 3:03:18 pm
Final Cut Pro 7 crashes whenever I try opening a clip (double-clicking on a clip) or when I drag and drop a clip into my timeline.
I just installed FCP7 on my new MacBook Pro a couple of days back, and I have never encountered this problem when I edited with FCP7 on my iMac before.
The footage I'm trying to edit are rips off YouTube in .mp4 and .FLV formats. I understand this might be seen as the cause of the problem, but I also tried to open a new sequence, in a new project, and opening new clips (.mp4 that has been recorded with a Sony A33), and the same problem happens.
I am editing using a scratch disk with 248GB available, shouldn't be a problem with the small amount of clips I have. It is formatted as Mac OS Extended (Journaled).
The sequence settings are
Frame Size: 720 x 480 (NTSC DV 3:2)
Pixel Aspect Ratio: NTSC - CCIR 601 / DV
Field Dominance: Lower (Even)
Editing Timebase: 29.97
QuickTime Video Settings
Compressor: DV/DVCPRO - NTSC
Quality: 100%
Audio Settings
Rate: 48kHz
Depth: 16-bit
Config: Channel Grouped
I would change the sequence settings, but FCP7 crashes whenever I attempt to.
My MacBook Pro is an Early 2011 model, 2.7GHz Intel Core i7, 8GB RAM 1333 MHz DDR3, OSX Mountain Lion, recently updated to 10.8.2.
This is the crash log, if it even helps.
Process: Final Cut Pro [598]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [218]
User ID: 503
Date/Time: 2012-09-20 07:53:25.066 -0700
OS Version: Mac OS X 10.8.2 (12C54)
Report Version: 10
Interval Since Last Report: 2575 sec
Crashes Since Last Report: 4
Per-App Interval Since Last Report: 1614 sec
Per-App Crashes Since Last Report: 4
Anonymous UUID: C0C47A90-9D57-DD5A-3C30-0B0A665E7503
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
__TEXT 0000000000001000-0000000000871000 [ 8640K] r-x/rwx SM=COW /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 ??? 0000000000 0 + 0
1 com.digidesign.digiVOUTcomponent 0x29dc0c37 DigiCodec_DrawBand + 145
2 com.apple.CoreServices.CarbonCore 0x91c36adb callComponentStorage_44 + 25
3 com.apple.CoreServices.CarbonCore 0x91c27abf CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 45
4 com.apple.CoreServices.CarbonCore 0x91c27aff CallComponentFunctionWithStorageProcInfo + 30
5 com.digidesign.digiVOUTcomponent 0x29dc0f5d DigiCodec_ComponentDispatch + 148
6 com.apple.CoreServices.CarbonCore 0x91ba1aee CallComponent + 151
7 com.apple.CoreServices.CarbonCore 0x91ba1b48 CallComponentDispatch + 29
8 com.apple.QuickTimeComponents.component 0x954f4c21 0x94963000 + 12131361
9 com.apple.QuickTimeComponents.component 0x9505251b 0x94963000 + 7271707
10 com.apple.QuickTimeComponents.component 0x95053aef 0x94963000 + 7277295
11 com.apple.QuickTimeComponents.component 0x95054ea8 0x94963000 + 7282344
12 com.apple.CoreServices.CarbonCore 0x91c36adb callComponentStorage_44 + 25
13 com.apple.CoreServices.CarbonCore 0x91c27abf CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 45
14 com.apple.CoreServices.CarbonCore 0x91c27aff CallComponentFunctionWithStorageProcInfo + 30
15 com.apple.QuickTimeComponents.component 0x95051187 Base_CDComponentDispatch + 81
16 com.apple.CoreServices.CarbonCore 0x91ba1aee CallComponent + 151
17 com.apple.CoreServices.CarbonCore 0x91ba1b65 DelegateComponentCall + 24
18 com.apple.CoreServices.CarbonCore 0x91ba1aee CallComponent + 151
19 com.apple.CoreServices.CarbonCore 0x91ba1b48 CallComponentDispatch + 29
20 com.apple.QuickTime 0x9047df4d ImageCodecBandDecompress + 43
21 com.apple.QuickTime 0x90471b05 DoBandedDecompress + 17336
22 com.apple.QuickTime 0x9046d600 ICMAction + 1062
23 com.apple.QuickTime 0x9046cfd0 ICMDeviceLoop + 3924
24 com.apple.QuickTime 0x904d4531 PrivateDecompressImage + 1345
25 com.apple.QuickTime 0x905027ec PrivateStdPix + 2028
26 com.apple.QD 0x9450ea86 QDStdPix + 103
27 com.apple.QuickTime 0x904d3bcd DecompressImage + 355
28 com.apple.FinalCutPro 0x001b5302 CopyCanvasToPixmap(KGCanvasRec*, OpaqueGrafPtr*, KGRect*, GDevice**, OpaqueRgnHandle*, unsigned char, unsigned long, unsigned long, KGTargetRec*, unsigned long long, KGPlayerRec*) + 3010
29 com.apple.FinalCutPro 0x001b581e KGTargetBlitTo(KGCanvasRec*, KGPlayerRec*, unsigned long long) + 558
30 com.apple.FinalCutPro 0x001b6f48 CompressToVideo(KGPlayerRec*) + 1494
31 com.apple.FinalCutPro 0x001b9e1e RenderTimer(long, long, KGDictInt*, void*) + 26
32 com.apple.FinalCutPro 0x00150000 KGTimerInvoke(__EventLoopTimer*, void*) + 212
33 com.apple.HIToolbox 0x93bb954c TimerVector + 22
34 com.apple.CoreFoundation 0x9832f9b6 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
35 com.apple.CoreFoundation 0x9832f355 __CFRunLoopDoTimer + 709
36 com.apple.CoreFoundation 0x98314162 __CFRunLoopRun + 1730
37 com.apple.CoreFoundation 0x9831363a CFRunLoopRunSpecific + 378
38 com.apple.CoreFoundation 0x983134ab CFRunLoopRunInMode + 123
39 com.apple.HIToolbox 0x93ba915a RunCurrentEventLoopInMode + 242
40 com.apple.HIToolbox 0x93ba8ec9 ReceiveNextEventCommon + 374
41 com.apple.HIToolbox 0x93d0e35d _AcquireNextEvent + 68
42 com.apple.HIToolbox 0x93cfd11a RunApplicationEventLoop + 225
43 com.apple.FinalCutPro 0x001539d1 KGMainEvent(void*) + 51
44 com.apple.FinalCutPro 0x002c1278 main + 54
45 com.apple.FinalCutPro 0x00002d5b _start + 209
46 com.apple.FinalCutPro 0x00002c89 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x990da9ae kevent + 10
1 libdispatch.dylib 0x98c35c71 _dispatch_mgr_invoke + 993
2 libdispatch.dylib 0x98c357a9 _dispatch_mgr_thread + 53
Thread 2:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x990d9be6 __select + 10
1 com.apple.CoreFoundation 0x98357c00 __CFSocketManager + 1632
2 libsystem_c.dylib 0x99d13557 _pthread_start + 344
3 libsystem_c.dylib 0x99cfdcee thread_start + 34
Thread 3:
0 libsystem_kernel.dylib 0x990d98e2 __psynch_cvwait + 10
1 libsystem_c.dylib 0x99d18289 _pthread_cond_wait + 938
2 libsystem_c.dylib 0x99da5afc pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043f42b Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x0042911f DisplayQueue::Run() + 681
5 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
6 libsystem_c.dylib 0x99d13557 _pthread_start + 344
7 libsystem_c.dylib 0x99cfdcee thread_start + 34
Thread 4:
4 com.apple.FinalCutPro 0x004e67c3 WorkUnitPerformer::Run() + 55
Thread 5:
0 libsystem_kernel.dylib 0x990d77d2 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x990d6cb0 mach_msg + 68
2 com.apple.CoreFoundation 0x9830e599 __CFRunLoopServiceMachPort + 185
3 com.apple.CoreFoundation 0x98313f7f __CFRunLoopRun + 1247
4 com.apple.CoreFoundation 0x9831363a CFRunLoopRunSpecific + 378
5 com.apple.CoreFoundation 0x983134ab CFRunLoopRunInMode + 123
6 com.apple.CoreMediaIOServicesPrivate 0x01104b76 MIO::DAL::RunLoop::OwnThread(void*) + 146
7 com.apple.CoreMediaIOServicesPrivate 0x0110706f CAPThread::Entry(CAPThread*) + 151
8 libsystem_c.dylib 0x99d13557 _pthread_start + 344
9 libsystem_c.dylib 0x99cfdcee thread_start + 34
Thread 6:
5 com.apple.CoreFoundation 0x98323061 CFRunLoopRun + 129
6 com.apple.qmaster.do 0x2c9c6460 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
7 com.apple.AECore 0x2c381022 aecore::CThread::runThread() + 34
8 com.apple.AECore 0x2c37efb9 threadProc(void*) + 17
9 libsystem_c.dylib 0x99d13557 _pthread_start + 344
10 libsystem_c.dylib 0x99cfdcee thread_start + 34
Thread 7:
1 com.apple.AECore 0x2c381067 aecore::CThread::runThread() + 103
2 com.apple.AECore 0x2c37efb9 threadProc(void*) + 17
3 libsystem_c.dylib 0x99d13557 _pthread_start + 344
4 libsystem_c.dylib 0x99cfdcee thread_start + 34
Thread 8:
2 libsystem_c.dylib 0x99d18512 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x91c066ad TSWaitOnConditionTimedRelative + 177
4 com.apple.CoreServices.CarbonCore 0x91c06184 TSWaitOnSemaphoreCommon + 272
5 com.apple.CoreServices.CarbonCore 0x91c0640d TSWaitOnSemaphoreRelative + 24
6 com.apple.QuickTimeComponents.component 0x94f595ac 0x94963000 + 6251948
7 libsystem_c.dylib 0x99d13557 _pthread_start + 344
8 libsystem_c.dylib 0x99cfdcee thread_start + 34
Thread 9:
0 libsystem_kernel.dylib 0x990da0ee __workq_kernreturn + 10
1 libsystem_c.dylib 0x99d1604c _pthread_workq_return + 45
2 libsystem_c.dylib 0x99d15e19 _pthread_wqthread + 448
3 libsystem_c.dylib 0x99cfdcca start_wqthread + 30
Thread 10:
Thread 11:
Thread 12:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x4e0a7020 ebx: 0x2bc8b030 ecx: 0x7c6b1405 edx: 0x00172dcf
edi: 0x00000000 esi: 0x2bc8af84 ebp: 0xbfffd768 esp: 0xbfffd70c
ss: 0x00000023 efl: 0x00210286 eip: 0x00000000 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 0
Binary Images:
0x1000 - 0x870ffc com.apple.FinalCutPro (7.0.3 - 7.0.3) <41B8A263-80F3-BCC3-FE28-82DE571687A1> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xc2e000 - 0xc31ff7 +KGCore (1) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xc39000 - 0xc39fff com.apple.iokit.dvcomponentglue (2.0.7 - 2.0.7) /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xc3d000 - 0xc4cfff com.apple.AERegistration (1.2 - 77) <5D18C47F-6F9E-0C4C-8875-24A14A97186D> /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xc60000 - 0xc67fff com.apple.AEProfiling (1.2 - 22) <43A46C32-8E13-82DD-8AF1-2A40690BF810> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xc71000 - 0xea2ff3 com.apple.prokit (7.3.1 - 1943) <4F8BB1EA-FA77-3B98-8889-8045F3F23A38> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xfba000 - 0x102cfef com.apple.ProFX (1.2.3 - 1.2.3) <06B47AC3-9449-A6F0-E189-09D4D1E29A5A> /Library/Application Support/ProApps/*/ProFX.framework/Versions/A/ProFX
0x104e000 - 0x10aaffb com.apple.proapps.MIO (1.0.5 - 509) <3FE469A6-C937-1E44-F79C-9AAA7C902A92> /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x10e7000 - 0x10f0ff7 com.apple.finalcutstudio.prometadatasupport (0.6 - 1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x10f8000 - 0x1130ff3 com.apple.CoreMediaIOServicesPrivate (52.0 - 3311.1) <1F651752-FD09-3CF5-BCCC-5C1366DDFACD> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x114b000 - 0x1172ff7 com.apple.CoreMediaPrivate (20.0 - 20.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x1185000 - 0x119aff7 com.apple.iChat.InstantMessage (7.0.1 - 3305) <2EB77610-6036-3CCD-9A93-51F7D6DE6EB2> /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
0x11a8000 - 0x11d9ff3 com.apple.FWAVCPrivate (52.47 - 47) <14C9A9D3-4065-3395-A8BC-C0535162017E> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x11ee000 - 0x120cfef com.apple.XSKey (1.0.0 - 52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
0x121b000 - 0x1263ffb com.apple.CoreMediaIOServices (171.0 - 3244) <9563BB38-F23A-3FC6-855D-05487E700465> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x1284000 - 0x1323fff com.apple.imcore (8.0 - 900) <2052F6C8-BDD3-339B-B0E2-6A3E282010A4> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
0x1349000 - 0x139dff7 com.apple.imfoundation (8.0 - 900) <7A1506BB-DDAD-3DB7-8557-19AB1B519FB0> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x13c8000 - 0x13d0ff7 com.apple.marco (8.0 - 900) /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x13d7000 - 0x1482fff libcrypto.0.9.7.dylib (106) <041B3399-5033-3395-9A71-6693F3A33D94> /usr/lib/libcrypto.0.9.7.dylib
0x1738000 - 0x1745ff3 com.apple.Librarian (1.1 - 1) <88A55A5E-40FF-3234-8394-2317120B79AB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x179e000 - 0x17daff7 com.apple.vmutils (4.2.1 - 108) <6918860D-B24F-356C-9374-025BFFEA66A3> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x5425000 - 0x54e3ff3 ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x5570000 - 0x557dff7 +net.telestream.license (1.0.8.2-GC - 1.0.8.2-GC) /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0x581b000 - 0x5822ffc com.apple.AppleGVAHW.component (1.1 - 1) <402A3FA9-6028-3639-989F-E9FCA85D04CF> /System/Library/QuickTime/AppleGVAHW.component/Contents/MacOS/AppleGVAHW
0xebaa000 - 0xebb2ff7 com.apple.proapps.mrcheckpro (1.4 - 398) <400C6D0F-2AC3-F06D-E20C-741BA3D9A558> /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0xec30000 - 0xec32fff libCoreFSCache.dylib (24.4) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0xec61000 - 0xec63ff3 com.apple.LiveType.component (2.1.4 - 2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0xec69000 - 0xeccdfe2 com.apple.LiveType.framework (2.1.4 - 2.1.4) /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
0xeced000 - 0xed33ffb com.apple.motion.component (1.0 - 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0xed39000 - 0xed3bff7 Motion (729) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0xed41000 - 0xeddeff8 com.apple.procore.framework (4.0.2 - 757) /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
0xf61a000 - 0xf7a6ff8 GLEngine (8.6.1) <2660B1D4-5783-3BED-8C05-F5A4C5A29715> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xf7dd000 - 0xf92eff7 libGLProgrammability.dylib (8.6.1) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0xf95c000 - 0xfcd5ff3 com.apple.driver.AppleIntelHD3000GraphicsGLDriver (8.0.61 - 8.0.0) <15005A8D-8CE9-30E1-A7F8-E894AB2B0E82> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
0xfddc000 - 0xfde8ffb libGPUSupport.dylib (8.6.1) /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0xfdef000 - 0xfe1bffa GLRendererFloat (8.6.1) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0xfe24000 - 0xfe2cffc libcldcpuengine.dylib (2.1.19) /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0xfe55000 - 0xfe7fff7 com.apple.FinalCutPro.Plugins.AfterEffects (7.0.3 - 7.0.3) <11BBAC1F-38D0-7A1B-0ECD-821729B3AF1B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0xfe87000 - 0xfe8bff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0xfe90000 - 0xfea7ff3 com.apple.FinalCutPro.Plugins.AudioMixer (7.0.3 - 7.0.3) <3C914C5E-510C-EBF8-2FD9-6450CBE8FD46> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0xfeb2000 - 0xfefaffb com.apple.audio.midi.CoreMIDI (1.9 - 78) <7AAE4076-36FA-37C1-9EAE-344F1C8F14D9> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xff1f000 - 0xff49feb com.apple.proapps.ControlSurfaceSupport (2.0 - 68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0xff6a000 - 0xff80ffc libexpat.1.dylib (12) /usr/lib/libexpat.1.dylib
0xff89000 - 0xff8efff com.apple.FinalCutPro.Plugins.Cache Manager (7.0.3 - 7.0.3) <7E686BFA-2AB3-442B-4203-1D8BA4EA5DA2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0xff93000 - 0xffadfff com.apple.FinalCutPro.CinemaTools (5.0 - 5.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0xffb9000 - 0xffc3ff9 com.apple.FinalCutPro.Plugins.CTHelper (7.0.3 - 7.0.3) <4B1D1B9F-16CB-A86E-E385-B82C12CF7DE9> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0xffca000 - 0xfff0ff7 com.apple.FinalCutPro.Plugins.EditTape (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0x10000000 - 0x10060fef com.apple.proapps.AudioMixEngine (2.0 - 68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x20091000 - 0x20099fff com.apple.FinalCutPro.Plugins.Effect Builder (7.0.3 - 7.0.3) <47BE0505-F602-9535-8684-EAF732016E93> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0x2009e000 - 0x200a9ffe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport (7.0.3 - 7.0.3) <41DA2698-9984-6241-130D-AACA55C647B4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0x200b2000 - 0x200e5ff7 com.apple.FinalCutPro.Plugins.FCS Engine (7.0.3 - 7.0.3) <1D178B47-1E72-47D8-D52D-EE1590B4F5AA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0x200ef000 - 0x200f2ffc com.apple.FinalCutPro.Plugins.FinalTouchExport (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0x200f8000 - 0x200f9fff com.apple.FinalCutPro.Plugins.Text Window (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0x20200000 - 0x202d8ff2 com.apple.FinalCutPro.Plugins.Browser (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0x202f6000 - 0x20351ff5 com.apple.FinalCutPro.Plugins.EDL Export (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0x20366000 - 0x20377ff7 com.apple.FinalCutPro.Plugins.FilterCustomEd (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0x2037d000 - 0x20392ffb com.apple.FinalCutPro.Plugins.FilterViewer (7.0.3 - 7.0.3) <8DA6D80C-B3A2-B2FF-6F2F-A44122508E27> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0x20398000 - 0x203b6fea com.apple.FinalCutPro.Plugins.Flash (7.0.3 - 7.0.3) <2CEAAEE1-4EF6-7180-2CAA-6DDE45E667DB> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0x203c2000 - 0x203cfffb com.apple.FinalCutPro.Plugins.GenViewer (7.0.3 - 7.0.3) <724F50F6-7A13-D6C3-B7CB-63CB23829F27> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0x203d5000 - 0x203d9fff com.apple.FinalCutPro.Plugins.LayerFileReader (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0x203de000 - 0x2042aff3 com.apple.FinalCutPro.Plugins.Media Manager (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0x20434000 - 0x20446ff0 com.apple.FinalCutPro.Plugins.MolokiniSupport (7.0.3 - 7.0.3) <85EAB333-1140-0657-27FF-B21F7DAEB40E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0x20455000 - 0x20469fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation (1.0 - 1.0) <7A59B9CD-7B44-2258-E79B-FCC5F9CAB309> /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0x20477000 - 0x204a9ffb com.apple.FinalCutPro.Plugins.Motion Viewer (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0x204ba000 - 0x204d5ff3 com.apple.FinalCutPro.Plugins.Movie Analyzer (7.0.3 - 7.0.3) <82EA8688-294B-3739-E719-09275DD966A7> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0x204e4000 - 0x204faffb com.apple.FinalCutPro.Plugins.Movie Viewer (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0x20506000 - 0x2050afff com.apple.FinalCutPro.Plugins.NuggetExport (7.0.3 - 7.0.3) <83A2CB39-EA91-DB85-E458-DDA09C4F9793> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0x2050f000 - 0x205c8fe7 com.apple.FinalCutPro.Plugins.OMF Audio Export (7.0.3 - 7.0.3) <1515F152-5847-223C-E5FE-CA894EDF121C> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0x205db000 - 0x205e3ffb com.apple.FinalCutPro.Plugins.Perf Analyzer (7.0.3 - 7.0.3) <1E04DC98-638A-CB1E-C04E-3B0C0E3CD199> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0x205e8000 - 0x205fdffb com.apple.FinalCutPro.Plugins.ProAppsIntegration (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0x2060d000 - 0x2061aff7 com.apple.FinalCutPro.Plugins.Pulldown Support (7.0.3 - 7.0.3) <555A8A21-3312-5CA8-FDA3-433F997DA91E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0x20622000 - 0x20661fef com.apple.FinalCutPro.Plugins.QTM Reader (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0x2066e000 - 0x20676ff3 com.apple.FinalCutPro.Plugins.QuickView (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0x2067b000 - 0x2068bffe com.apple.FinalCutPro.Plugins.Relink Media (7.0.3 - 7.0.3) <67805834-C6B2-061D-7581-E3D7835DB779> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0x20692000 - 0x2072bff2 com.apple.FinalCutPro.Plugins.Timeline Editor (7.0.3 - 7.0.3) <1870750B-B6C6-9132-E680-CA9338AE23D6> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0x2073a000 - 0x2074bfff com.apple.FinalCutPro.Plugins.Transcoder (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0x20755000 - 0x20767fff com.apple.FinalCutPro.Plugins.Transition Viewer (7.0.3 - 7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0x2076d000 - 0x20782ff3 com.apple.FinalCutPro.Plugins.Trimming (7.0.3 - 7.0.3) <449089A2-91B0-4CC7-2A2C-0DD44827F041> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0x20788000 - 0x2078effb com.apple.FinalCutPro.Plugins.VDUSupport (7.0.3 - 7.0.3) <33F34BB0-DEBD-B056-BB0F-1F419E20E990> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0x20794000 - 0x20795ffb com.apple.FinalCutPro.Plugins.Vector Accelerator (7.0.3 - 7.0.3) <6FC3291F-5227-348F-8994-EA598417AAEA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0x2079a000 - 0x207abfff com.apple.FinalCutPro.Plugins.VideoLog (7.0.3 - 7.0.3) <1700D722-D1CB-90C0-8248-FD0FD5DD1EC6> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0x207b0000 - 0x207c8ff7 com.apple.FinalCutPro.Plugins.VoiceOver (7.0.3 - 7.0.3) <049BB860-4BA1-7AAB-3836-973493389CF0> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0x207cf000 - 0x207d0ffd com.apple.ironwoodcore (1.1.1 - 1.1.1) <098CE576-3239-3B41-9141-A5BE6E476C84> /System/Library/PrivateFrameworks/SpeechObjects.framework/Versions/A/Frameworks/DictationServicesCore.framework/DictationServicesCore
0x21800000 - 0x2187dfe1 com.apple.FinalCutPro.Plugins.XML Support (7.0.3 - 7.0.3) <09E858FB-A896-3DF9-46DB-751E6884D820> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0x21d66000 - 0x21d67ff5 +cl_kernels (???) cl_kernels
0x21d7e000 - 0x21d91fef com.apple.FCP Uncompressed 422.component (2.0 - 546.9) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x21d96000 - 0x21dd3fe7 com.apple.DVCPROHDCodec (2.0 - 542.4) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x21de3000 - 0x21dfbff2 com.apple.applepixletvideo (1.2.31 - 1.2d31) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x21fdf000 - 0x21fe0ffd +cl_kernels (???) cl_kernels
0x21fe4000 - 0x21fe4ff7 +cl_kernels (???) <4BF1A479-F66D-41B8-8F15-DB62009FFCA6> cl_kernels
0x228f2000 - 0x22906fef com.apple.fcp.DVOutputUnit (1.3 - 1.3) <691D07F3-84FB-39BE-AB16-213751718437> /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0x22ab6000 - 0x22ad7fff com.apple.AppleIntermediateCodec (2.0.1 - 5718) <6A70694B-21C7-381B-8DE3-CD6490C70A77> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x22ae6000 - 0x22aeaff3 com.apple.SmoothCamFxPlug (1.0.1 - 1.0.1) /Library/Application Support/ProApps/*/SmoothCam
0x22af1000 - 0x22af1ffc com.apple.qmaster.swamp (3.5.3 - 3.5.3) <7766A14C-1FFD-C0FD-5BB3-5269DE4C4CF7> /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x22d00000 - 0x22d87ff7 com.apple.AppleProResCodec (3.0.1 - 553.2) <6E207B31-DE83-BF92-990F-24328404C5AF> /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
0x22dc5000 - 0x22e79fef com.apple.AppleHDVCodec (2.0.1 - 553.8) <5F48585B-5E48-549D-1E1B-F1BF68F8B753> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x22e95000 - 0x22eabffb com.apple.IMXCodec (2.0 - 547.2) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x22ebd000 - 0x22ef7fff com.apple.QuickTimeFireWireDV.component (7.7.1 - 2599.13) <5FB303B9-3672-39AA-8CD6-E323CC0E41A8> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x23800000 - 0x23b8ffff QuickTimeH264.scalar (2599.13) <40E122CF-721A-338C-94BB-D6CB892851EA> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0x23d0e000 - 0x23d46fff com.apple.motion.MotionBundle (4.0.2 - 729) <993F121D-D2DE-C81D-B38C-692283E9A29A> /Library/Application Support/ProApps/*/Motion.bundle/Contents/MacOS/Motion
0x23df9000 - 0x23dfaff7 com.apple.Helium (3.0.3 - 359) <1B909921-EE16-B317-3670-B0C63C70F01B> /Library/Application Support/ProApps/*/Helium.framework/Versions/A/Helium
0x23f00000 - 0x23ffeff7 com.apple.soundtrackpro.integration (3.0 - 3.0) /Library/Application Support/ProApps/*/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0x2402f000 - 0x24764fdf +com.borisfx.TextScrambler (2.1) /Library/Application Support/Final Cut Pro System Support/*/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
0x251a3000 - 0x25288fe7 +libMXF.dylib (1) /Library/Application Support/Neyrinck/*/libMXF.dylib
0x2531e000 - 0x2534cff7 +libMXFClient.dylib (1) /Library/Application Support/Neyrinck/*/libMXFClient.dylib
0x25524000 - 0x25529fff com.apple.audio.AppleHDAHALPlugIn (2.3.1 - 2.3.1f2) <58BDA15D-2B2D-3E77-BC8C-D14AB1E4AC4E> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x255f6000 - 0x255f7fff com.apple.FxHeliumImage (4.0.0 - 1.0) <62A25655-AB02-73F7-FE2B-21823D2D4BA4> /Library/Application Support/ProApps/*/FxHeliumImage.framework/Versions/A/FxHeliumImage
0x25856000 - 0x25f88fc7 +com.borisfx.Title3D (2.1) /Library/Application Support/Final Cut Pro System Support/*/Title 3D.bundle/Contents/MacOS/Title 3D
0x269c6000 - 0x269d5ff7 com.apple.QuartzComposer.FxPlugWrapper (1.2.3 - 92) /Library/Application Support/ProApps/*/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
0x269e0000 - 0x269ecfff com.apple.PluginManager (1.7.6 - 55) <26D4CD2F-E9C5-327B-BABD-CAAA0E84D7E0> /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
0x269f8000 - 0x269fafff com.apple.Helium.HCache (2.1.0 - 359) <669FD4C8-B9A0-549E-EC32-C49718676C34> /Library/Application Support/ProApps/*/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
0x26b00000 - 0x27230fef +com.borisfx.TitleCrawl (2.1) /Library/Application Support/Final Cut Pro System Support/*/Title Crawl.bundle/Contents/MacOS/Title Crawl
0x27c6d000 - 0x283a3ff7 +com.borisfx.VectorShape (2.1) /Library/Application Support/Final Cut Pro System Support/*/Vector Shape.bundle/Contents/MacOS/Vector Shape
0x28dee000 - 0x28df6ff7 com.apple.QuartzComposer.QCMotionPatch (1.0 - 729) <104A0B24-6D0D-DEEA-6543-753BB407D16A> /Library/Application Support/ProApps/*/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
0x28f00000 - 0x29302fe7 +com.neyrinck.au.soundcode.dolbye (2.0.0.29 - 2.0.0.29) <882D99D6-85D2-E301-DB3B-5CE535E6BCD0> /Library/Audio/Plug-Ins/Components/SoundCode Dolby E Decode.component/Contents/MacOS/SoundCode Dolby E Decode
0x29525000 - 0x29536ff7 com.apple.fxplugframework (1.2.3 - 1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
0x29549000 - 0x2969bfec com.apple.Helium.HeliumRender (2.0.3 - 359) <93D90702-A8F2-B483-818A-6C5E85D7000F> /Library/Application Support/ProApps/*/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0x296f4000 - 0x2995efe2 com.apple.motion.filters (4.0.2 - 604) <43E12D87-F63D-496D-3143-61C198C179BD> /Library/Application Support/ProApps/*/Filters.bundle/Contents/MacOS/Filters
0x29a17000 - 0x29b19ff2 +com.REVisionEffects.RSMB_FXPlug (4.0 - 4.0) <811241ED-4377-4C85-E6C0-9490439467A2> /Library/Plug-ins/*/RSMB
0x29b64000 - 0x29b8cfe3 com.apple.AppleAVCIntraCodec (2.0 - 542.4) /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0x29b96000 - 0x29bc7fe3 +com.digidesign.digidesign.DigiCoreAudioPlugIn (8.0.3 - 8.0.3f251) /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio
0x29bfe000 - 0x29c09ff0 com.apple.fcp.TundraOutputUnit (1.3.1 - 1.3.1) <71D84D8B-50CF-D900-8558-EDEA70827C8F> /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
0x29c12000 - 0x29c1dff7 com.apple.DVCPROHDVideoOutput (1.3.2 - 1.3.2) <738D36A7-8DBD-3BD7-CD35-4B171397782C> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
0x29c25000 - 0x29c8afe0 com.apple.DVCPROHDMuxer (1.3.2 - 1.3.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x29ca4000 - 0x29cdcffb com.apple.audio.SoundManager.Components (4.0 - 4.0) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x29ce3000 - 0x29da0fe2 com.apple.DesktopVideoOut (1.2.7 - 1.2.7) <54E0C747-1169-FB4A-2CB4-9EA9BD5398F8> /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0x29dbf000 - 0x29dc0ff7 +com.digidesign.digiVOUTcomponent (8.0.3 - 8.0.3f251) <822B418F-4AB9-A775-57EC-11AB98195B77> /Library/QuickTime/DigiVout.component/Contents/MacOS/DigiVout
0x29dc5000 - 0x29ddefff com.apple.promath.framework (4.0.2 - 729) /Library/Application Support/ProApps/*/ProMath.framework/Versions/A/ProMath
0x29de8000 - 0x29df4fff com.apple.FinalCutPro.iChatTheaterPreview (1.0 - 195) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
0x29dfc000 - 0x29dfcff7 libffi.dylib (18) <362F6C27-6407-388E-9521-8A2A0845188C> /usr/lib/libffi.dylib
0x29f00000 - 0x2a7e1fe2 com.apple.ozone.framework (4.0.3 - 729) /Library/Application Support/ProApps/*/Ozone.framework/Ozone
0x2ac83000 - 0x2ad4bffa org.python.python (2.5.6 - 2.5) <1F100B5F-891C-3FF8-9183-C1443861D594> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
0x2ad8b000 - 0x2aef3ff2 com.apple.ProMedia (4.0.2 - 729) <07F6C2C0-ACFD-27D8-D887-74E47F0196F9> /Library/Application Support/ProApps/*/ProMedia.framework/Versions/A/ProMedia
0x2af64000 - 0x2afceff2 com.apple.ProGraphics (4.0.3 - 729) /Library/Application Support/ProApps/*/ProGraphics.framework/Versions/A/ProGraphics
0x2b0eb000 - 0x2b108ff1 libedit.2.dylib (31) /usr/lib/libedit.2.dylib
0x2b116000 - 0x2b29afe2 com.apple.Lithium (4.0.2 - 729) <228EB85A-BDBC-55EE-9AC6-E4990DB34DFF> /Library/Application Support/ProApps/*/Lithium.framework/Versions/A/Lithium
0x2b321000 - 0x2b332fff com.apple.RetimingMath (4.0.2 - 729) <2ED17500-06D7-08B5-441F-AFE5DDDE71AD> /Library/Application Support/ProApps/*/RetimingMath.framework/Versions/A/RetimingMath
0x2b347000 - 0x2b415ff3 com.apple.prochannel.framework (4.0.2 - 763) <721D6E76-2081-097D-4C2E-22C6162B8DDB> /Library/Application Support/ProApps/*/ProChannel.framework/Versions/A/ProChannel
0x2b4b4000 - 0x2b4eaffa com.apple.proinspector.framework (4.0.2 - 761) /Library/Application Support/ProApps/*/ProInspector.framework/Versions/A/ProInspector
0x2b50d000 - 0x2b8c1ff2 com.apple.motion.TextFramework (4.0.2 - 729) /Library/Application Support/ProApps/*/TextFramework.framework/TextFramework
0x2bd00000 - 0x2be97ff8 com.apple.motion.Behaviors (4.0.2 - 729) <052F3433-97BD-1C55-C23D-AD92143C71F8> /Library/Application Support/ProApps/*/Behaviors
0x2bf36000 - 0x2bf81ff4 com.apple.Bloodhound (4.0.2 - 729) /Library/Application Support/ProApps/*/Bloodhound.framework/Versions/A/Bloodhound
0x2bfac000 - 0x2c149ff8 com.apple.motion.Particles (4.0.2 - 729) <049BF10B-9B06-52CF-E500-79AE1AB90ED4> /Library/Application Support/ProApps/*/Particles
0x2c1a5000 - 0x2c1b7fff com.apple.motion.Text (4.0.2 - 729) <21A95797-1AC2-730A-8063-57A923D7F70A> /Library/Application Support/ProApps/*/Text
0x2c1c4000 - 0x2c1c9ffb com.apple.fxmetaplug.ImageUnit (1.2.2 - 1.2.2) <874EE8A7-B644-32C8-D8E2-1E4EA379C31B> /Library/Application Support/ProApps/*/ImageUnit
0x2c1d0000 - 0x2c1d9fff com.apple.IOFWDVComponents (2.0.7 - 2.0.7) /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x2c1e4000 - 0x2c1eeff7 com.apple.compressor.MediaServerAPI (3.5.3 - 3.5.3) /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
0x2c300000 - 0x2c338ff7 com.apple.CompressorKit (3.5.3 - 3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
0x2c367000 - 0x2c4c1ff7 com.apple.AECore (3.5.3 - 3.5.3) <2BAD733C-D2F3-F9FD-C5CD-22C23820EE15> /Library/Frameworks/AECore.framework/Versions/A/AECore
0x2c559000 - 0x2c5fbfef com.apple.compressor.StompUI (3.5.3 - 3.5.3) <6E15FAA4-A6BA-3DCD-0607-5ECBDDE1439D> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x2c659000 - 0x2c742fe3 com.apple.compressor.StompTypes (3.5.3 - 3.5.3) <8ACF288B-C692-9A76-182F-1327BF365470> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x2c7cb000 - 0x2c7d6fff com.apple.compressor.StompUtil (3.5.3 - 3.5.3) <7589A431-23FA-B445-A452-7E3E99DF531B> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x2c7e5000 - 0x2c819fff com.apple.qmaster.SwampCore (3.5.3 - 3.5.3) <173511EA-C5F3-D58C-3A56-A99C3BED8506> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x2c844000 - 0x2c84ffff com.apple.qmaster.SwampUtil (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x2c85c000 - 0x2c925fe3 com.apple.qmaster.SwampTypes (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x2c9b3000 - 0x2ca27ff8 com.apple.qmaster.do (3.5.3 - 3.5.3) <4CE7B752-D141-5B9D-6248-8A6A6E0240F9> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x2ca90000 - 0x2ca99fff com.apple.qmaster.SwampService (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x2caa9000 - 0x2cab3fff com.apple.qmaster.Status (3.5.3 - 3.5.3) <750051BA-26B7-52BD-0636-F2F1F3DB9EED> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x2cac8000 - 0x2cad3fff com.apple.qmaster.RequestProcessing (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x2cae7000 - 0x2cafaffb com.apple.qmaster.ServiceControl (3.5.3 - 3.5.3) <01DD590C-6953-D428-FEFC-A59CDAD53349> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x2cb13000 - 0x2cb80ff7 com.apple.qmaster.ContentControl (3.5.3 - 3.5.3) <79754868-87EA-467B-D09C-C4579E6F2E6E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x2cbc8000 - 0x2cbd3fff com.apple.qmaster.ClusterManager (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x2cbe2000 - 0x2cc0cff7 com.apple.qmaster.SwampUI (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x2cc31000 - 0x2cc3cfff com.apple.qmaster.SwampExecutor (3.5.3 - 3.5.3) <85C50FA9-CDBD-B8FD-D271-1B7275A7CF49> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x2cc50000 - 0x2cc69ff7 com.apple.ScriptingBridge (1.3 - 61.2) <74397541-E4DD-3DCA-BA5F-F7AAF145819A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x2cc78000 - 0x2cc84fff com.apple.dsppublishing (1.0.1 - 119) <2C4E2A5C-6E41-2CD9-533B-36145D1C7987> /Library/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
0x2cc95000 - 0x2cccdfff com.apple.compressor.ImageProcessing (3.5.3 - 3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x3be04000 - 0x3bec9fff com.apple.qmaster.JobControl (3.5.3 - 3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x3bf52000 - 0x3c0f2ffb com.apple.compressor.transcoding (3.5.3 - 3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x3c219000 - 0x3c21ffff com.apple.compressor.FilterUI (3.5.3 - 3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x3c228000 - 0x3c255ff3 com.apple.audio.CoreAudioKit (1.6.4 - 1.6.4) <5F0E55AF-BDA6-36B3-86F2-8A84A8F5D089> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x3c268000 - 0x3c26dfe7 com.apple.H264Encoder (1.0 - 21) /Library/Application Support/ProApps/*/H264Encoder.framework/Versions/A/H264Encoder
0x3c279000 - 0x3c27affe com.apple.AddressBook.LocalSourceBundle (2.1 - 1167) <341A7E90-613E-3306-919F-8F49EE350831> /System/Library/Address Book Plug-Ins/LocalSource.sourcebundle/Contents/MacOS/LocalSource
0x3c2d6000 - 0x3c2dbff1 com.apple.finalcutpro.dvcprohdfrcplugin (1.2.0 - 16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
0x3c2e2000 - 0x3c2e5ffe com.apple.DirectoryServicesSource (2.1 - 1167) <2A3AD43B-950C-32AD-A578-3271EAD55E3E> /System/Library/Address Book Plug-Ins/DirectoryServices.sourcebundle/Contents/MacOS/DirectoryServices
0x3c7ea000 - 0x3c7f2ff3 com.apple.AppSandbox (2.0 - 1) <5C586FB0-9EBB-3F14-A63F-497C7A034359> /System/Library/PrivateFrameworks/AppSandbox.framework/AppSandbox
0x3d1ff000 - 0x3d47bff7 +com.neyrinck.soundcode.dolbye.proplug (1.0) /Library/Application Support/Final Cut Pro System Support/*/SoundCode Dolby E.bundle/Contents/MacOS/SoundCode Dolby E
0x3e9b6000 - 0x3ea35ff7 com.apple.iLifeMediaBrowser (2.7.2 - 546) <824E7748-CA28-3105-B5C3-27E9D8C6D465> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x41dac000 - 0x41dacffd +cl_kernels (???) cl_kernels
0x41fcd000 - 0x41fdaffb com.apple.KerberosHelper (4.0 - 1.0) <6CB4B091-3415-301A-87B2-D9D374D0FC17> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
0x41fe4000 - 0x41ff3ffd com.apple.NSServerNotificationCenter (5.0 - 5.0) /System/Library/Frameworks/ServerNotification.framework/Versions/A/ServerNotification
0x42f5f000 - 0x42fa1fff com.apple.facetimeservices (8.0 - 900) /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices
0x42fb9000 - 0x42ffaff3 com.apple.ExchangeSource (2.1 - 1167) <2AC25C8B-F633-3786-B2B8-530E86B14F06> /System/Library/Address Book Plug-Ins/Exchange.sourcebundle/Contents/MacOS/Exchange
0x43014000 - 0x43061ffb com.apple.ExchangeWebServices (3.0 - 157) <29FBE8CC-2EC5-3209-B2CB-DD32E3E2ECC7> /System/Library/PrivateFrameworks/ExchangeWebServices.framework/Versions/A/ExchangeWebServices
0x430b5000 - 0x43106ff7 com.apple.AddressBook.CardDAVPlugin (10.8 - 332) /System/Library/Address Book Plug-Ins/CardDAVPlugin.sourcebundle/Contents/MacOS/CardDAVPlugin
0x43123000 - 0x43185fff com.apple.coredav (1.0.1 - 179.6) <80D3EE71-AA9C-3954-B262-6BB8FCB293BC> /System/Library/PrivateFrameworks/CoreDAV.framework/Versions/A/CoreDAV
0x431bf000 - 0x431c6ff7 com.apple.AOSNotification (1.7.0 - 636.2) /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x431d0000 - 0x4322cfff com.apple.corelocation (1.0 - 1239.39) <8159C021-DE49-332F-859E-00D7544EB568> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x43259000 - 0x4328bff3 com.apple.GeoServices (1.0 - 1) <2E4033FA-18BD-3E73-B00E-CBFEE0ACCB6A> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x4329d000 - 0x432a6fff com.apple.ProtocolBuffer (2 - 104) /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x432d5000 - 0x432fcff3 libsandbox.1.dylib (220) /usr/lib/libsandbox.1.dylib
0x43303000 - 0x43316ff3 com.apple.AppContainer (2.0 - 1) <799C8E8B-F983-3A3D-91CF-A2C9B5B7D007> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x43325000 - 0x43329fff com.apple.SecCodeWrapper (2.0 - 1) /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x43330000 - 0x43334ffe libMatch.1.dylib (17) <29090908-32A9-3087-B197-00128F5954CD> /usr/lib/libMatch.1.dylib
0x43d56000 - 0x43f5bfff com.apple.audio.codecs.Components (3.0 - 3.0) /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x4481e000 - 0x448b0ff7 unorm8_bgra.dylib (2.1.19) /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x4bf8b000 - 0x4bfd4fff com.apple.AppleVAH264HW.component (3.0 - 3.0) <3048BA40-0E8E-357A-8F9D-27D2FD322036> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x4c200000 - 0x4c4f0feb +org.perian.Perian (1.2.3 - 1.2.3) <722FFF4F-46EF-E5BE-70A6-42B5873D2B37> /Users/USER/Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x4db11000 - 0x4dd06ff2 +net.telestream.wmv.import (2.4.0.11 - 2.4.0.11) <83F7489B-3935-E1BA-B934-69179217A26D> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x4dd3b000 - 0x4defdff2 +net.telestream.wmv.advanced (2.4.0.11 - 2.4.0.11) <92B25580-FF56-5E91-902F-D1DC3E7EC9C2> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x4df41000 - 0x4e08bff7 com.apple.AppleGVAFramework (4.0.27 - 4.0.27) /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0x70000000 - 0x7015dff7 com.apple.audio.units.Components (1.8 - 1.8) <2637680C-A07E-3387-BD21-33B04B7C7A95> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe92000 - 0x8fec4e57 dyld (210.2.3) <23516BE4-29BE-350C-91C9-F36E7999F0F1> /usr/lib/dyld
0x90007000 - 0x90103ff3 com.apple.DiskImagesFramework (10.8 - 344) <98C16F91-9D3E-3FD0-A30B-BD49EE4ED9A4> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x90104000 - 0x901fcff9 libsqlite3.dylib (138.1) /usr/lib/libsqlite3.dylib
0x901fd000 - 0x90207fff libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
0x90208000 - 0x90231ff7 libRIP.A.dylib (324.6) <7976E6A2-A489-33F5-A727-7634DDE3B761> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90232000 - 0x90462fff com.apple.QuartzComposer (5.1 - 284) <4E8682B7-EBAE-3C40-ABDB-8705EC7952BD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x90463000 - 0x906dfff7 com.apple.QuickTime (7.7.1 - 2599.13) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x906e0000 - 0x90748fe7 libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x90749000 - 0x90755ffa com.apple.CrashReporterSupport (10.8.2 - 414.3) <15321A03-11A6-39BE-B6F5-422F382B34AC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x90756000 - 0x90b73fff FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x90b74000 - 0x90b75ffd libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
0x90b76000 - 0x90b7cfff com.apple.phonenumbers (1.1 - 47) /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x90b7d000 - 0x90deafff com.apple.imageKit (2.2 - 667) <3F5F92DB-C0C0-3C5F-98C6-B84AB9E28B55> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x90df1000 - 0x90df9fff com.apple.CommerceCore (1.0 - 26) /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x90dfa000 - 0x90e30ffb com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x90e31000 - 0x90e7fff3 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <7BA6C58B-0357-356F-BB69-17ACB5E35988> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90e80000 - 0x90e82ffb libRadiance.dylib (845) <3F87840F-217D-3074-A29D-919BAAED2F4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x90e83000 - 0x90e91fff com.apple.opengl (1.8.6 - 1.8.6) <1AD1AE7B-B57B-35B5-B571-32A34F0DA737> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90e92000 - 0x90f0eff3 com.apple.Metadata (10.7.0 - 707.3) <6B6A6216-23D0-34CE-8099-BEE9BA42501E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9178c000 - 0x917a2fff com.apple.CFOpenDirectory (10.8 - 151.10) <56C3F276-BD1F-3031-8CF9-8F4F481A534E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x917a3000 - 0x917d1ff3 com.apple.framework.Admin (12.0 - 12.0) /System/Library/PrivateFrameworks/Admin.framework/Versions/A/Admin
0x917d2000 - 0x918e2ff3 com.apple.QuickTimeImporters.component (7.7.1 - 2599.13) <410311C4-34FF-38F0-8EE0-3093AEEC1A82> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x918e3000 - 0x918e3fff libSystem.B.dylib (169.3) <81C58EAB-0E76-3EAB-BDFD-C5A6FE95536F> /usr/lib/libSystem.B.dylib
0x918e4000 - 0x9197bff7 com.apple.ink.framework (10.8.2 - 150) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9197c000 - 0x91a87ff7 libJP2.dylib (845) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91a88000 - 0x91a98ff2 com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91a99000 - 0x91a99fff com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x91a9d000 - 0x91aa9ffe libkxld.dylib (2050.18.24) <48A75AF6-9D5A-3552-948E-30A1682D3664> /usr/lib/system/libkxld.dylib
0x91aaa000 - 0x91b01ff7 com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x91b02000 - 0x91b05ff7 libcompiler_rt.dylib (30) /usr/lib/system/libcompiler_rt.dylib
0x91b43000 - 0x91e48ff7 com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <4571EDDC-704A-3FB1-B9A6-59870AA6165F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x91e49000 - 0x91fa6ffb com.apple.QTKit (7.7.1 - 2599.13) <2DC9E2BB-9895-3D02-A318-88431052E70B> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x91fa7000 - 0x91fcbfff libJPEG.dylib (845) <547FA9A5-0BBB-3E39-BACA-F3E2DAE57DB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91fcc000 - 0x92063ffb libCoreStorage.dylib (274.7) <1F99649B-4407-35F2-B419-9FE010360816> /usr/lib/libCoreStorage.dylib
0x92064000 - 0x9206dff3 com.apple.DisplayServicesFW (2.6.1 - 353) <50D0BBF0-F911-380F-B470-E59B5E48E520> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x92776000 - 0x92776fff libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
0x92777000 - 0x92868ffc libiconv.2.dylib (34) /usr/lib/libiconv.2.dylib
0x9286b000 - 0x92c67feb com.apple.VideoToolbox (1.0 - 926.62) /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x92c68000 - 0x92c76ff3 libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
0x92c77000 - 0x92d95ff7 com.apple.MediaControlSender (1.4.5 - 145.3) /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x92d96000 - 0x92ddfff7 com.apple.framework.CoreWLAN (3.0.1 - 301.11) /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x92de2000 - 0x92deeff8 libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
0x92def000 - 0x92eedff7 libFontParser.dylib (84.5) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x92eee000 - 0x92f30ffb com.apple.RemoteViewServices (2.0 - 80.5) <60E04F2F-AFD8-3B1F-BF07-8A3A7EABB8E9> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x92f31000 - 0x92f88ff3 com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92f89000 - 0x92f8bffc com.apple.QuickTimeH264.component (7.7.1 - 2599.13) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x92f8c000 - 0x92f99fff libGL.dylib (8.6.1) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f9a000 - 0x92fdcff7 libauto.dylib (185.1) /usr/lib/libauto.dylib
0x92fdd000 - 0x92fe8fff libcommonCrypto.dylib (60026) /usr/lib/system/libcommonCrypto.dylib
0x92fe9000 - 0x9307bffb libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9307c000 - 0x931d4ffb com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <9205DFC2-8DAE-354E-AD87-46E229B5F2F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x931d5000 - 0x93216ff7 com.apple.framework.CoreWiFi (1.0 - 100.10) <944B3FAE-F901-3276-A676-9D52295DA817> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x93217000 - 0x9325eff3 com.apple.CoreMedia (1.0 - 926.62) <69B3835E-C02F-3935-AD39-83F8E81FB780> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9325f000 - 0x932b8fff com.apple.AE (645.3 - 645.3) <6745659F-006D-3F25-94D6-DF944E9A01FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x932b9000 - 0x93309ff7 com.apple.CoreMediaIO (301.0 - 4147) /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x9330a000 - 0x9333dff5 libssl.0.9.8.dylib (47) <3224FBB3-3074-3022-AD9A-187703680C03> /usr/lib/libssl.0.9.8.dylib
0x9333e000 - 0x935e1ffb com.apple.CoreImage (8.2.2 - 1.0.1) <85BFFB09-D765-3F5F-AF65-FB136DDCAEF3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x935e2000 - 0x9363ffff com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93640000 - 0x9364affb libcsfde.dylib (274.7) <3560C5D0-59F3-311E-A298-1F71E4B58351> /usr/lib/libcsfde.dylib
0x9364b000 - 0x936a4fff com.apple.QuickLookFramework (4.0 - 555.4) <96911441-FDD4-3B68-9E0C-51BA11A97C2E> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x936a5000 - 0x938fdff1 com.apple.JavaScriptCore (8536 - 8536.26.7) <75629E05-65FE-3699-8CDC-80C95015CF42> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x938fe000 - 0x93907ffd com.apple.audio.SoundManager (4.0 - 4.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93908000 - 0x93957ff6 libTIFF.dylib (845) <989A2EB9-3A49-3157-8E9C-B16E6005BC64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x93958000 - 0x9395fffe com.apple.agl (3.2.1 - AGL-3.2.1) <8E0411D3-19F7-30E1-92A2-337F7F0EBCDA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x93960000 - 0x93a9bff7 libBLAS.dylib (1073.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x93a9c000 - 0x93a9cfff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x93a9d000 - 0x93af7fff com.apple.Symbolication (1.3 - 93) <684ECF0D-D416-3DF8-8B5B-3902953853A8> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x93af8000 - 0x93afbff7 com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x93afc000 - 0x93b2cfff libncurses.5.4.dylib (37.3) <30D8B67F-5447-34AB-900F-2D623CD4F117> /usr/lib/libncurses.5.4.dylib
0x93b2d000 - 0x93b31fff com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93b32000 - 0x93b50ff3 com.apple.openscripting (1.3.6 - 148.2) <55738D66-CC15-3F43-9265-00C3322D39C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93b51000 - 0x93f34ff3 com.apple.HIToolbox (2.0 - 625) <5A312E41-9940-363E-B891-90C4672E6850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93f5b000 - 0x93f5bfff com.apple.quartzframework (1.5 - 1.5) <9018BE5B-4070-320E-8091-6584CC17F798> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x93f5c000 - 0x93f63ff3 com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x93f64000 - 0x93f9bffa com.apple.LDAPFramework (2.4.28 - 194.5) <8368FAE7-2B89-3A7D-B6EE-7184B522CB66> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x93f9c000 - 0x94125ff7 com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94128000 - 0x941a4ffb libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x941a5000 - 0x941a8ffe com.apple.LoginUICore (2.0 - 2.0) <2CCB81A5-1194-3F16-8FD0-F779014E389D> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x941a9000 - 0x944c6ff3 com.apple.Foundation (6.8 - 945.11) <03B242AC-519C-3683-AA52-E73536B3D55F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x944c7000 - 0x94567ff7 com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x94568000 - 0x94675057 libobjc.A.dylib (532.2) /usr/lib/libobjc.A.dylib
0x94676000 - 0x946d1fff com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x946d2000 - 0x946f2ffd com.apple.ChunkingLibrary (2.0 - 133.2) /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x946ff000 - 0x946fffff com.apple.Carbon (154 - 155) <604ADD9D-5835-3294-842E-3A4AEBCCB548> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x94700000 - 0x94735fff libTrueTypeScaler.dylib (84.5) <2598F930-5E6B-37D7-B1E6-18181A972C6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x94736000 - 0x94739ff3 com.apple.AppleSystemInfo (2.0 - 2) <4639D755-8A68-31C9-95C4-7E7F70C233FA> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x9473a000 - 0x94793ff7 com.apple.ImageCaptureCore (5.0.1 - 5.0.1) <541529F7-063E-370B-9EB2-DF5BE39073E6> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x94794000 - 0x9490cff5 com.apple.QuartzCore (1.8 - 304.0) <0B0EC55A-9084-3E28-9A84-1813CE3FAA9B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9490d000 - 0x94922fff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94923000 - 0x94924fff libquarantine.dylib (52) /usr/lib/system/libquarantine.dylib
0x94925000 - 0x94950fff com.apple.shortcut (2.2 - 2.2) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x94951000 - 0x9495eff7 com.apple.HelpData (2.1.4 - 85) <1E180AEF-53FF-3D8B-9513-7FCA1B25A4AB> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x9495f000 - 0x94962ffb libutil.dylib (30) <605DD210-46C2-3D4A-8DC1-08B0E80694FD> /usr/lib/libutil.dylib
0x94963000 - 0x9569bff7 com.apple.QuickTimeComponents.component (7.7.1 - 2599.13) <85C70D1B-D074-3891-BF8D-9BA81D2C224B> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x956dc000 - 0x956eefff libbsm.0.dylib (32) /usr/lib/libbsm.0.dylib
0x956ef000 - 0x95706ff4 com.apple.CoreMediaAuthoring (2.1 - 914) <37C0A2C7-73B3-39BC-8DE1-4A6B75F115FC> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x95707000 - 0x95734ffb com.apple.CoreServicesInternal (154.2 - 154.2) /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x95735000 - 0x95739ffe libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
0x95744000 - 0x95745fff liblangid.dylib (116) /usr/lib/liblangid.dylib
0x95792000 - 0x95886ff3 com.apple.QuickLookUIFramework (4.0 - 555.4) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x95887000 - 0x958edffc com.apple.ISSupport (1.9.8 - 56) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x958ee000 - 0x9
Shane Ross
Re: FCP7 crashes whenever I try to open a clip
on Sep 20, 2012 at 4:00:45 pm
FCP doesn't work in the formats you are trying to import. It requires that you convert that footage to an FCP edit friendly codec, like ProRes. You MUST do this before editing that footage with FCP. If you want to edit those formats native, you need to use different editing software, like Adobe Premiere Pro, or Sony Vegas (PC only).
Shane
Little Frog Post
