Export from FCP 7 in sync on Mac but not on PC
Richard Lee
on Sep 15, 2012 at 9:11:42 am
Hi
Exported a DVPAL sequence from FCP7. This plays fine on the Mac but on a PC the audio is out of sync.
Any ideas on a possible cause?
Jeff Meyer
Re: Export from FCP 7 in sync on Mac but not on PC
on Sep 15, 2012 at 2:19:07 pm
If you're uisng a long GOP codec (any member of the mpeg4 family - H.264 included - or any member of the mpeg 2 family) try using an all I frame codec - DV, ProRes, or Animation.
Run updates on the PC. Look for updates to Quicktime, the video board, and the audio board.
If it's a slower computer try to stick to viewing it at 100%. Any other size involves scaling.
Richard Lee
on Sep 15, 2012 at 2:20:26 pm
Thanks, it is exported as DVPAL which is not long GOP. Also, I have tried viewing on several PCs and it is out of sync. I think there is a problem with the file but not sure what?
Jeff Meyer
on Sep 15, 2012 at 2:28:03 pm
Might give ProRes or Animation a try. If you do animation consider using AVI instead of Quicktime. In FCP you can use File -> Export -> Quicktime components to create AVI files.
